12748 Discussions
How to jump to labels which are defined in C code
In order to speed up system, I write a routine in ASM instructions. Then in asm code, I intend to jump to a label named LOOP which is defined in C code, but I failed. The following error occur:
void Fast_Copy_In_ASM(alt_u32* pSource, alt_u32* pDest, alt_u32 length)
LOOP:
asm("ldwio r7,0(r4)");
asm("stwio r7,0(r5)");
asm("addi r5,r5,4");//increase read_data to point to next byte
asm("addi r4,r4,4");//increase read_data to point to next byte
asm("addi r6,r6,-4");//decrease read_length
asm("bne r6,zero,LOOP ");//CWG2
error:undefined reference to ‘LOOP’
(1)How to jump to labels which are defined in C code from asm instruction?
(2)Also, pls kindly tell me does there exist any document related to C and ASM mixture coding?
Thanks any help!
David http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
That is basically inline GCC assembly... that follow the rules of GCC ... you can find many information on the web just searching for "inline gcc assembler" :-)
bye,
Paolo
Put the label inline as well: <div class='quotetop'>QUOTE </div>
--- Quote Start ---
asm volatile (
    "LOOP:  ldwio r7,0(r4)"
    "        stwio r7,0(r5)"
    "        addi r5,r5,4"
    "        addi r4,r4,4"
    "        addi r6,r6,-4"
    "        bne r6,zero,LOOP " \
);[/b]
--- Quote End ---
--Scott
smart idea http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Thanks very much!
Hi Scott:
I have tried your code, no compiling error occurred,but something was wrong.
The following code work fine.
asm("Fast_Copy_In_ASM_Loop: ldwio r7,0(r4)");
asm("bne r6,zero,Fast_Copy_In_ASM_Loop");//CWG2
But the code you showed me were all skipped when I step into it.
asm volatile (
" stwio r7,0(r5)"
" addi r5,r5,4"
" addi r4,r4,4"
" addi r6,r6,-4"
WHY?
best regards,
David
> WHY?
You might be stepping through each statement rather than each instruction.
Each "asm" is treated as a statement..
--Scott
Hi Scott:
But I can&#39;t find the corresponding code in Disassembly window.
So it might be optimized, am I right?
But my optimization level is -O0.
Can you help me to try the code?
SOURCE CODE
asm volatile (
"Fast_Copy_In_ASM_Loop1: ldwio r7,0(r4)"
" stwio r7,0(r5)"
" addi r5,r5,4"
" addi r4,r4,4"
" addi r6,r6,-4"
" bne r6,zero,Fast_Copy_In_ASM_Loop1 " \
//asm("Fast_Copy_In_ASM_Loop: ldwio r7,0(r4)");
//asm("stwio r7,0(r5)");
//asm("addi r5,r5,4");//increase read_data to point to next byte
//asm("addi r4,r4,4");//increase read_data to point to next byte
//asm("addi r6,r6,-4");//decrease read_length
//asm("bne r6,zero,Fast_Copy_In_ASM_Loop");//CWG2
Disassembly code
<span style="color:red"><span style="color:blue">void Fast_Copy_In_ASM(alt_u32* pSource, alt_u32* pDest, alt_u32 length)
10053f4: defffc04 addi sp,sp,-16
10053f8: df000315 stw fp,12(sp)
10053fc: d839883a mov fp,sp
1005400: e1000015 stw r4,0(fp)
1005404: e1400115 stw r5,4(fp)
1005408: e1800215 stw r6,8(fp)
0100540c <Fast_Copy_In_ASM_Loop1>:
asm volatile (
100540c: 29c00037 ldwio r7,0(r5)
" stwio r7,0(r5)"
" addi r5,r5,4"
" addi r4,r4,4"
" addi r6,r6,-4"
1005410: df000317 ldw fp,12(sp)
1005414: dec00404 addi sp,sp,16
1005418: f800283a ret</span></span>
Thanks a lot!
David
Duh ... sorry :
--- Quote Start ---
asm volatile (
    "0:    ldwio r7,0(r4)  \n"
    "          stwio r7,0(r5)  \n"
    "          addi r5,r5,4  \n"
    "          addi r4,r4,4  \n"
    "          addi r6,r6,-4    \n"
    "          bne r6,zero,0b \n"
);[/b]
--- Quote End ---
--Scott
Hi, Scott:
No sorry! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/happy.gif
Thanks very much!
Wish you a best christmas,
David
Hi, Scott:
Thanks very much!
David
