In order to speed up system, I write a routine in ASM instructions. Then in asm code, I intend to jump to a label named LOOP which is defined in C code, but I failed. The following error occur: void Fast_Copy_In_ASM(alt_u32* pSource, alt_u32* pDest, alt_u32 length) { LOOP: asm("ldwio r7,0(r4)"); asm("stwio r7,0(r5)"); asm("addi r5,r5,4");//increase read_data to point to next byte asm("addi r4,r4,4");//increase read_data to point to next byte asm("addi r6,r6,-4");//decrease read_length asm("bne r6,zero,LOOP ");//CWG2 } error:undefined reference to ‘LOOP’ (1)How to jump to labels which are defined in C code from asm instruction? (2)Also, pls kindly tell me does there exist any document related to C and ASM mixture coding? Thanks any help! David http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif链接已复制
9 回复数
Put the label inline as well: <div class='quotetop'>QUOTE </div> --- Quote Start --- asm volatile ( "LOOP: ldwio r7,0(r4)" " stwio r7,0(r5)" " addi r5,r5,4" " addi r4,r4,4" " addi r6,r6,-4" " bne r6,zero,LOOP " \ );[/b] --- Quote End --- Regards, --ScottHi Scott:
I have tried your code, no compiling error occurred,but something was wrong. The following code work fine. asm("Fast_Copy_In_ASM_Loop: ldwio r7,0(r4)"); asm("stwio r7,0(r5)"); asm("addi r5,r5,4");//increase read_data to point to next byte asm("addi r4,r4,4");//increase read_data to point to next byte asm("addi r6,r6,-4");//decrease read_length asm("bne r6,zero,Fast_Copy_In_ASM_Loop");//CWG2 But the code you showed me were all skipped when I step into it. asm volatile ( "LOOP: ldwio r7,0(r4)" " stwio r7,0(r5)" " addi r5,r5,4" " addi r4,r4,4" " addi r6,r6,-4" " bne r6,zero,LOOP " \ ); WHY? best regards, David> But the code you showed me were all skipped when I step into it.
... > WHY? You might be stepping through each statement rather than each instruction. Each "asm" is treated as a statement.. Regards, --ScottHi Scott:
But I can't find the corresponding code in Disassembly window. So it might be optimized, am I right? But my optimization level is -O0. Can you help me to try the code? SOURCE CODE void Fast_Copy_In_ASM(alt_u32* pSource, alt_u32* pDest, alt_u32 length) { asm volatile ( "Fast_Copy_In_ASM_Loop1: ldwio r7,0(r4)" " stwio r7,0(r5)" " addi r5,r5,4" " addi r4,r4,4" " addi r6,r6,-4" " bne r6,zero,Fast_Copy_In_ASM_Loop1 " \ ); //asm("Fast_Copy_In_ASM_Loop: ldwio r7,0(r4)"); //asm("stwio r7,0(r5)"); //asm("addi r5,r5,4");//increase read_data to point to next byte //asm("addi r4,r4,4");//increase read_data to point to next byte //asm("addi r6,r6,-4");//decrease read_length //asm("bne r6,zero,Fast_Copy_In_ASM_Loop");//CWG2 } Disassembly code <span style="color:red"><span style="color:blue">void Fast_Copy_In_ASM(alt_u32* pSource, alt_u32* pDest, alt_u32 length) { 10053f4: defffc04 addi sp,sp,-16 10053f8: df000315 stw fp,12(sp) 10053fc: d839883a mov fp,sp 1005400: e1000015 stw r4,0(fp) 1005404: e1400115 stw r5,4(fp) 1005408: e1800215 stw r6,8(fp) 0100540c <Fast_Copy_In_ASM_Loop1>: asm volatile ( 100540c: 29c00037 ldwio r7,0(r5) "Fast_Copy_In_ASM_Loop1: ldwio r7,0(r4)" " stwio r7,0(r5)" " addi r5,r5,4" " addi r4,r4,4" " addi r6,r6,-4" " bne r6,zero,Fast_Copy_In_ASM_Loop1 " \ ); //asm("Fast_Copy_In_ASM_Loop: ldwio r7,0(r4)"); //asm("stwio r7,0(r5)"); //asm("addi r5,r5,4");//increase read_data to point to next byte //asm("addi r4,r4,4");//increase read_data to point to next byte //asm("addi r6,r6,-4");//decrease read_length //asm("bne r6,zero,Fast_Copy_In_ASM_Loop");//CWG2 } 1005410: df000317 ldw fp,12(sp) 1005414: dec00404 addi sp,sp,16 1005418: f800283a ret</span></span> Thanks a lot! DavidDuh ... sorry :
<div class='quotetop'>QUOTE </div> --- Quote Start --- asm volatile ( "0: ldwio r7,0(r4) \n" " stwio r7,0(r5) \n" " addi r5,r5,4 \n" " addi r4,r4,4 \n" " addi r6,r6,-4 \n" " bne r6,zero,0b \n" );[/b] --- Quote End --- Regards, --ScottHi, Scott:
No sorry! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/happy.gif Thanks very much! Wish you a best christmas, DavidHi, Scott:
