How to update kernel?
When I compile some device driver, they need the kernel 2.6.16.1, But I don't how to update it form kernel 2.6.11-uc0.
I download linux-2.6.16.1, But I don't know how using it.
--- Quote Start ---
originally posted by claude@Apr 23 2006, 05:05 PM
when i compile some device driver, they need the kernel 2.6.16.1, but i don't how to update it form kernel 2.6.11-uc0.
i download linux-2.6.16.1, but i don't know how using it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14574)
--- quote end ---
--- Quote End ---
you can use this patch,
http://forum.niosforum.com/forum/index.php...ype=post&id=137 (http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=137
In general,
1. untar the kernel source from kernel.org
2. apply uc0 patch from uclinux.org
3. apply nios2nommu patch
You may find more kernel works by Jdhar on this forum.
hippo is referring to kernel snapshots that I periodically generate:
http://via.fps-tech.org/snapshots/ (http://via.fps-tech.org/snapshots/
hippos info is more cutting-edge and up to date however; it&#39;s hard to keep up with him http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
