IDE to CF
Hello!
I have a question about storage device.
If I install a "CF-to-IDE Adapter" on the proto2 (40pin IDE socket) of EP2C35 ,
Pins assignment have been change to proto2.
Then may I store data to CF card?
If it is workable ,
and I send a signal of ATAPI(IDE) to proto2 .
May I use hot-plugging (or Hot Swap) ?
I think it should work with ATA and ATAPI. The CF works at "true IDE mode".
And the CF has power on/off control. Hot-swap can be supported.
You can use uclinux to drive them.
You should also check the CF IP in,
Nios Discussion Board > Downloads > Tested IP
