12748 Discussions
NIOS II linker cannot find function that is referenced in the main source file
Quite strange error appears while building project:
undefined reference to `function1(unsigned long, unsigned long)
function1 is located in one of the project source files and corresponding# include directive does present in the source file where function1 is referenced.
Did someone experience such issues ?
Problem is resolved but the cause of problem remains obscure.
I changed extension of the file where function1 is defined ... from .c to .cpp
And it worked ... perhaps because the main source file (i.e. where is main function) is .cpp
Apparently, the g++ linker "doesn't like" mixing .c and .cpp sources.
