12748 讨论
NIOS V + DDR4 with problem for malloc
BrightEST-howard
初学者
1,293 次查看
We are currently conducting tests using Arria 10 GX EVB.
However, we have encountered an issue where NIOS V controlling DDR4 through EMIF IP results in a failure when attempting dynamic memory allocation in the software.
Strangely, this issue is resolved when we remove EMIF IP from the system.
Our system's diagram is attached for reference.
Attached is the project file used for testing.
Any guidance or suggestions would be greatly appreciated. Thank you!
Additionally, the initial problem arose from our attempt to add EMIF IP control for DDR4 based on Intel Simple Socket Server example. However, upon debugging, we found that the issue actually occurred during the initial dynamic memory allocation, causing subsequent execution to fail due to pointer unavailability, resulting in an "ethernet initial fail" message on the JTAG-UART terminal.
0 项奖励
3 回复数
JingyangTeh_Altera
964 次查看
Hi
Sorry for the late response.
I took a look at your project it seems like you did not connect the Nios to boot from the EMIF.
Could you try connecting the data and instruction manager of the NiosV to the EMIF controller and switching the reset vector to the EMIF?
​​​​​​​Jingyang, Teh
0 项奖励
JingyangTeh_Altera
848 次查看
Hi
Did you managed to try out the suggestion?
Jingyang, Teh
0 项奖励
JingyangTeh_Altera
810 次查看
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
0 项奖励
回复
