公告
12748 討論
Pausing target processor: not responding.
榮譽貢獻者 II
8,808 檢視
when i try to run as NIOS II hardware, i am getting this error,
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and trying again: FAILED
Leaving target processor paused
how can i correct it,
Its running in the simulator though (NIOS instruction set simulator)
0 積分
17 回應
榮譽貢獻者 II
6,638 檢視
The compilation msgs shown are, as in attached file , it shows timing reqs not met
榮譽貢獻者 II
6,638 檢視
It is possible that your processor is held in reset at the firmware level. Make sure your processor has a valid clock and that the reset polarity is correct.
榮譽貢獻者 II
6,638 檢視
I agree with kosh271
Check resets connection (in top level, a lot of times the problem is there).
榮譽貢獻者 II
6,638 檢視
I used the example came with the De2 115 board
I am new to fpga , can you help me in sort out , where can i change the clock and reset ?
I attached a screen shot of my configurations
榮譽貢獻者 II
6,638 檢視
kindly someone assist me
榮譽貢獻者 II
6,638 檢視
The compilation messages indicate that you don't have the license for the Nios CPU. This means Quartus generates a time limited .sof file for evaluation purposes. When you configure the FPGA you will see an OpenCore window saying you are in evaluation mode. Do not close this window or the Nios CPU will stop working and you can get this "non responding" error.
榮譽貢獻者 II
6,638 檢視
yes , i didnt closed the window , then also the same problem persists
榮譽貢獻者 II
6,638 檢視
Did you modify the example in any way? Check epsecially the clock and reset input. The reset is active low so it must be high for the system to work. You can verify that the clock is running by using signaltap, either by monitoring the clock signal itself, or by using it as the clock in signaltap (it will say "waiting for clock" if the clock isn't toggling).
榮譽貢獻者 II
6,638 檢視
what these lines show ?
Warning (10034): Output port "LEDR" at myfirst_niosii.v(44) has no driver
Warning (10034): Output port "FL_ADDR" at myfirst_niosii.v(47) has no driver
Warning (10034): Output port "FL_CE_N" at myfirst_niosii.v(48) has no driver
Warning (10034): Output port "FL_OE_N" at myfirst_niosii.v(50) has no driver
Warning (10034): Output port "FL_RST_N" at myfirst_niosii.v(51) has no driver
Warning (10034): Output port "FL_WE_N" at myfirst_niosii.v(53) has no driver
Warning (10034): Output port "FL_WP_N" at myfirst_niosii.v(54) has no driver
榮譽貢獻者 II
6,638 檢視
It means that you defined some output ports on your top level verilog file that you didn't connect to anything inside your design.
榮譽貢獻者 II
6,638 檢視
hello,
i am currently working on DE2 70 altera kit for my final year project and want to send messages using ethernet port. i am working using SOPC builder. Firstly i want to run a small program(eg. LEDs). i have created a NIOS II system using SOPC builder, then i have used altera monitor program to compile a c program.
system got downloaded on to the board but when i m trying to load it i am getting the following error.
Usingcable "USB-Blaster [USB-0]", device1,instance 0x00
Pausingtargetprocessor: not responding.
Leavingtargetprocessorpaused
please kindly help me to sort this error.
榮譽貢獻者 II
6,638 檢視
Did you chech the clock and reset signals, as already suggested in the thread?
榮譽貢獻者 II
6,638 檢視
i have assigned the clock and reset to iCLK_50 and iKEY(0) in the pin assignment vhdl file. but still it doest work. arent they correct?
榮譽貢獻者 II
6,638 檢視
Can you check the polarity of your reset signal? The reset input on an SOPC/QSYS design is active low, so it needs to be '1' for the CPU to work. I don't know the polarity of the KEY signals on the DE2 board.
榮譽貢獻者 II
6,638 檢視
I had some problems with the board,
now got response from the board
榮譽貢獻者 II
6,638 檢視
I had a similar problem that was solved by making sure the NIOS reset output (jtag_debug_module_reset) is connected to the reset inputs of the other components, including the NIOS itself (reset_n). The loading process was unable to pause the processor until this change was made.
榮譽貢獻者 II
6,638 檢視
I too got similar error and resolved it by making sure that my Clock and Reset pins at the top level were correctly assigned (Pin Planner/ Assignment Editor). Once fixed, this resolved the problem.
So it appears, for such messages, one must look closely at the top level (including Nios / Connected components) Clock and Reset connections.
回覆
