12748 讨论
Pausing target processor : not responding
名誉分销商 II
1,928 次查看
Hi all !. I m stucked withe the following problem :
My system is built with a NIOS II, JTAG UART, one AM29LV065D flash, and 2 IDT71V416S RAM.
I am using Quartus 4.2 SP1, IDE 1.1. When I try to run a hello world on my IDE console
I get the following message :
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and trying again : FAILED
leaving target processor paused[/B][/b]
--- Quote End ---
I did the following test to check my design :
- run Hello world from an onchip memory : OK
- run few Write and Read cycle to my external memories from an onchip memory : OK
- run Hello world from my external Flash memory : NOK
- run Hello world from my external Ram memory : NOK
- Check power supply on RAM and Flash : OK
- Check access timing on RAM and Flash : OK
- Download program to flash with IDE Flash programmer : OK
- Try different PLL frequency to the NIOS from 50 MHZ to 80 MHz.
I am really running out of solutions now !. Heeeeeeeeeelp please !!!.
greg http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
0 项奖励
6 回复数
名誉分销商 II
892 次查看
--- Quote Start ---
run Hello world from my external Flash memory: NOK[/b]
--- Quote End ---
What do u mean? Have u downloaded to flash your program and configuration data?Is your reset address in flash space (SOPC setting)?and program and data memory setting in IDE?
bye
0 项奖励
名誉分销商 II
892 次查看
WE added a pull up on the CS of the flash and RAM and it works fine now. Thanks for your efforts.
0 项奖励
名誉分销商 II
892 次查看
--- Quote Start ---
originally posted by gregoryw@Jun 8 2005, 05:17 AM
we added a pull up on the cs of the flash and ram and it works fine now. thanks for your efforts.
--- Quote End ---
How exactly did you do that? Is that a pull up resistor on one of the FPGA pins?
0 项奖励
名誉分销商 II
892 次查看
I soldered on the board a 5K resistor pull up to the 3.3V on both Flash and RAM.
0 项奖励
名誉分销商 II
892 次查看
is this on a development board or your own custom solution?
0 项奖励
名誉分销商 II
892 次查看
I had to do that on 2 different custom boards.
0 项奖励
回复
