12748 Discussions
Problem building a program with Nios II IDE : undefined reference to 'main'
Hi everyone.
I'm a newbie at using Nios II IDE, and I'd like to run a C++ program I did on Cyclone II Development Board. For that, I created a "nios ii application with bsp template" with a .sopcinfo file that a coworker gave me. I created a "Hello_world" project and I renamed "hello_world.c" into "hello_world.cc" because I want to program in C++.
I'll now talk about the following program :
#include <iostream># include "system.h" int main() { return 0; } My problem is that I can't build that simple program, because I get the following error :
--- Quote Start ---
../Test_bsp/libhal_bsp.a(alt_main.o)(.text+0x58): In function `alt_main':
d:/Algo_Nios/software/Test_bsp/HAL/src/alt_main.c:165: undefined reference to `main'
--- Quote End ---
which refers to the following lines in "alt_main.c" :
#ifdef ALT_NO_EXIT main (alt_argc, alt_argv, alt_envp);# else result = main (alt_argc, alt_argv, alt_envp); <-- that's the line close(STDOUT_FILENO); exit (result);# endifI've tried various things, like including the "alt_main.h" librairy, or type "int alt_main()" instead of "int main()", but no matter what I do, I can't build the project.
I'd appreciate any help or hints to solve my problem.
Tthegarde
File name extension does matter. For instance, if you change the filename to "hello_world.cpp", it works.
Jake
I would report this to Altera.
Table 4-3 on page 4-5 of the "NIOS II Software Developer's Handbook":
http://www.altera.com/literature/hb/nios2/n2sw_nii5v2.pdf
indicates that the ".cc" extension is supported. However, the Altera plugin for eclipse is not adding files with this extension to the Makefile automatically.
Jake
Thanks for your quick answer Jakobjones. I did renamed my file into "xxx.cpp" and it builds correctly.
I did thought that the ".cc" extension was supported because I saw it in the Project --> "Properties / C/C++ General / File Types" and it was associated with "C++ Source Files" ...
I'll check if that issue is not already known, and eventually report it to Altera.
Tthegarde
Hi all,
I just had the same error whereas I work in C and not in C++ (enable_c_plus_plus option unchecked).
The solution I found is to delete the /libhal_bsp.a file from the BSP and generate then clean -> build the project again and now it works.
I've tried to regenerate the error without success.
Maybe it can help some of you.
I did same way what you have mention here. I am still getting this errors undefined reference to fread, fopen, fseek
Figured our another way around this. When I was creating the project from BSP file in Nios II Eclipse, the project directory already existed (and contained 2 source files inside). Apparently if the wizard isn't the one creating the folder, it will give you that error. So I renamed the folder to 'sources', created the project 'pname' in folder 'pname' that was not there and it worked.
