12745 Discussions
Problem with concurrent sending and receiving data with ethernet
I'm working with the Simple Socket Server example for my DE4-230 board (that is...blinking Leds and 7segments display example....). I modified this example simply adding a" while (stop==1)...etc etc" to send random 32bit data to pc when nios system receives a command (an ASCII character 'L') from my client Labwindows program. These 32 bit data are effectively received continuously but when I try to send from Labwindows another command (i.e: those for managing blinking Leds or socket closing...) it seems that communication towards nios II is blocked...and so the loop data receiving is unstoppable...
Any Ideas??
regards
--- Quote Start ---
--- Quote End ---
Lean back an think what you are doing. Without escaping the loop, the server won't handle any new commands, isn't it?
yes...It is....I know that...but I don't know as I could do this kind of operation (I mean... this loop data sending controlling its starting and stopping from pc) I tried also to create a new task in which there is this "while(stop==0)" with a fixed priority, I tried to delayed the task execution to allow processor to execute other tasks...but the situation was the same!!!...
nothing???
How should I do to take control of my system during this continuously data sending???
