12744 Discussions
Update nios-linux 20100621 buid error
Contributeur émérite II
1 847 Visites
After update nios-linux 20100621, when i make, get error :
{standard input}: Assembler messages:
{standard input}:365: Error: unrecognised instruction initda
make[3]: *** [arch/nios2/mm/memory.o] Error 1
make[2]: *** [arch/nios2/mm] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/root/nios2-linux/linux-2.6'
make: *** [linux] Error 1
Who knows to help me?
0 Compliments
11 Réponses
1 026 Visites
Got same error when starting to play around with uclinux some time ago.
Hope I remember right when I tell you to check
a) your branches
b) your toolchain
So when working without mmu you should use nios2gcc-20080203.tar.bz2 and test-nios2 branches,
when working with mmu you should use toolchain-mmu and branches trunk (uClinux-dist) / nios2 (linux-2.6)
Hope this helps.
Andi
0 Compliments
1 026 Visites
I'm sure to use nios2gcc-20080203.tar.bz2 and test-nios2 branches (uClinux-dist & linux-2.6)
and i make succesfull but not detected USB 1-0 : 1 port detected ,so i try to update and get above error
can you see my post and help me
http://www.alteraforum.com/forum/showthread.php?t=34708
0 Compliments
1 026 Visites
I solved this problem with mount USB on uclinux and you shouldn't update source
0 Compliments
1 026 Visites
A quick 'RTFM' shows that the 'initda' instruction was added in rev 8.0 in May 2008. So it is likely that the toolchain you are using predates that change.
0 Compliments
1 026 Visites
--- Quote Start ---
Hallo kinhcan89,
can u tell me how did you solve this Problem? i am having the same one! i Know its one year ago but maybe u remember :-).
0 Compliments
1 026 Visites
--- Quote Start ---
--- Quote Start ---
Hallo kinhcan89,
--- Quote End ---
Which toolchain do you use and which branch do you use (mmu / nommu)?
0 Compliments
1 026 Visites
--- Quote Start ---
--- Quote Start ---
--- Quote End ---
I am using pre-build toolchain nios2gcc-20080203.tar.bz2 and test-nios2 branches(uClinux-dist and Linux-2.6).
0 Compliments
1 026 Visites
--- Quote Start ---
--- Quote Start ---
--- Quote End ---
I can remember that this was the wrong toolchain for systems with mmu. nios2gcc-20080202 prebuilt toolchain was for use with nommu-systems. The error message you posted looks like this is the problem here, too.
0 Compliments
1 026 Visites
--- Quote Start ---
--- Quote Start ---
--- Quote End ---
My Hardware Architect don't have on chip memory, I am using nommu system.
0 Compliments
1 026 Visites
Maybe you should build the tool chain like:
cd nios2-linux/toolchain-build
git clean -f -x -d# clean on restart
make gcc
make elf2flt
Then,use the new compiler you made.
PATH=$PATH:/home/(user name)/nios2-linux/toolchain-build/build/nios2/bin
Regards.
0 Compliments
1 026 Visites
Sorry to annoy you all but I'm trying to build the uClinux on DE2 Cyclone 2 (an old kit). I've had the same error and as far as I realized this is because the nios-linux version is new (nios2-linux-20120802) so may be it's not compatible with the NO MMU. However, I can't find any old version of this file like nios-linux-20090730 since all the links died. So anyone can show me how to fix the problem or provide with the link to download the old version to test.
Thank you all.
0 Compliments
Répondre
