12745 Discussions
Why does .bss section load to UFM flash memory in MAX10 QSYS project?
OGavr
I use Quartus 16.1 and MAX10 device 10M16DAF256I7G. I create project with NIOS QSYS. I place NIOS code in UFM memory, and RAM in onchip RAM. I create BSP automatic and not change it. I know, that .rwdata section is relocable and loaded in flash. But I see, that .bss section is placed in flash too. It write in UFM 4 kB zeroes. Why does it do it?
This is objdump output:
proj.elf:    file format elf32-littlenios2
proj.elf
architecture: nios2:r1, flags 0x00000112:
EXEC_P, HAS_SYMS, D_PAGED
start address 0x00008180
Program Header:
   LOAD off   0x00001000 vaddr 0x00008000 paddr 0x00008000 align 2**12
        filesz 0x00000020 memsz 0x00000020 flags r-x
   LOAD off   0x00001020 vaddr 0x00008020 paddr 0x00008020 align 2**12
        filesz 0x000029fc memsz 0x000029fc flags r-x
   LOAD off   0x00004000 vaddr 0x00010000 paddr 0x0000aa1c align 2**12
        filesz 0x00000124 memsz 0x0000131c flags rw-
Sections:
Idx Name         Size     VMA      LMA      File off Algn
 0 .entry       00000020 00008000 00008000 00001000 2**5
                 CONTENTS, ALLOC, LOAD, READONLY, CODE
 1 .exceptions  00000160 00008020 00008020 00001020 2**2
 2 .text        00002808 00008180 00008180 00001180 2**2
 3 .rodata      00000094 0000a988 0000a988 00003988 2**2
                 CONTENTS, ALLOC, LOAD, READONLY, DATA
 4 .rwdata      00000124 00010000 0000aa1c 00004000 2**2
                 CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA
 5 .bss         000011f8 00010124 0000ab40 00004124 2**2
                 ALLOC, SMALL_DATA
 6 .onchip_flash_0_data 00000000 0000ab40 0000ab40 00004124 2**0
                 CONTENTS
 7 .onchip_memory2_0 00000000 0001131c 0001131c 00004124 2**0
                 CONTENTS
 8 .comment     00000023 00000000 00000000 00004124 2**0
                 CONTENTS, READONLY
.bss is UFM address.
I not change linker.x script. At this scrip I find:
.bss : { __bss_start = ABSOLUTE(.); PROVIDE (__sbss_start = ABSOLUTE(.)); PROVIDE (___sbss_start = ABSOLUTE(.));   *(.dynsbss) *(.sbss .sbss.* .gnu.linkonce.sb.*) *(.sbss2 .sbss2.* .gnu.linkonce.sb2.*) *(.scommon)   PROVIDE (__sbss_end = ABSOLUTE(.)); PROVIDE (___sbss_end = ABSOLUTE(.));   *(.dynbss) *(.bss .bss.* .gnu.linkonce.b.*) *(COMMON)   . = ALIGN(4); __bss_end = ABSOLUTE(.); } > onchip_memory2_0
 I try add NOLOAD option to .bss with no effect.
GuaBin_N_Intel
Each of section can be put to different memory regions by user through linker's memory map.  ​Refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf, 7.15.2.1 and figure 12
.text—All remaining code
.rodata—The read-only data
.rwdata—Read-write data
.bss—Zero-initialized data
