12648 Discussions
XML error when creating a component in SOPC
Hi everyone ,
When creating a new component in SOPC , I got 2 errors :
(1)
Error (10509): Verilog HDL XML interface error at b.v(130): parameter of packed array type is not supported. File: G:/b.v Line: 130
The content of g:/b.v on line 130 is :
130 : parameter [4:0] Reg0 = 5'b00_000, Reg1 = 5'b00_001;
(2)
Error (10670): Verilog HDL or VHDL error: cannot create XML design interface for design file G:/b.v. File: G:/b.v Line: 56
The content of g:/b.v on line 56 is :
56 : module b(
57 : // port declaration
Have you met these kinds of error before ? What should I do to fix this problem ?
Thanks in advance,
Quan
i only know vhdl but perhaps this thread may help you
see thread
"Something strange with SOPC, The editing of exist component has fell"
http://www.niosforum.com/pages/forum.php?cat_id=5 (http://www.niosforum.com/pages/forum.php?cat_id=5
answer from slava
Hi All!
Now altera have answered me
and l should replace lines
parameter[3:0] IADDR = 4'hB;
parameter[3:0] IDATA = 4'hC;
with lines
parameter IADDR = 4'hB;
parameter IDATA = 4'hC;
The reason is "This can not pass the component editor"
With best regards,
Slava.
i hope this link works:
I thought you might be interested in reading this web page: http://forum.niosforum.com/forum/index.php?act=st&f=2&t=3558 (http://forum.niosforum.com/forum/index.php?act=st&f=2&t=3558)
--- Quote Start ---
i thought you might be interested in reading this web page: http://forum.niosforum.com/forum/index.php?act=st&f=2&t=3558 (http://forum.niosforum.com/forum/index.php?act=st&f=2&t=3558
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17594)
--- quote end ---
--- Quote End ---
Hi Fischer ,
Your link is pretty helpful to me. Now I try it and let you know the result as soon as I can.
Thank you very much,
Quan
--- Quote Start ---
--- quote end ---
--- Quote End ---
Hi ,
The link is really cool !!!!! Following the thread , some files could be successfully fixed (both error(1) and error(2) ) but some files still remain error (2).
What should I do to solve the rest ?
Thanks so much ,
Quan
