Comunicados
adding build steps
Colaborador honorário II
1.004 Visualizações
I would like to be able to add steps into the build process. Ideally, I would like to add a pre-link compilation of a file that bears our project's date code, and a couple of post link processes to create the (custom) flash images that we require.
Can this be done without assuming full responsibility for the Makefile?
1 Responder
307 Visualizações
Jim,
I'm not sure if there's a way, within the framework that the IDE provides, but most of the stuff that controls this build process is contained in:
<nios2_root>/components/altera_hal/build
Additionally, if you go to <nios2_root>/bin/eclipse/plugins/com.altera.nj.doc.user/reference/altera_build_environment.htm, you can find the details on the Nios II build environment there...so that you&#39;ll know where to modify things, if you need to.
- slacker
Responder
