alt_timestamp() question
Hi!
I am just wondering if my understanding of the alt_timestamp is totally wrong...
My oszillator clock is 50MHz which i can see in the sopc builder and which has never changed.
I configured a 32bit/1millisec interval timer in the sopc builder (i named it "TIMER_MSEC") for my nios ii and selected it to the timestamp timer in the BSP editor.
Here are the settings:# define ALT_MODULE_CLASS_Timer_Msec altera_avalon_timer# define TIMER_MSEC_ALWAYS_RUN 1# define TIMER_MSEC_BASE 0x0# define TIMER_MSEC_COUNTER_SIZE 32# define TIMER_MSEC_FIXED_PERIOD 0# define TIMER_MSEC_FREQ 50000000u# define TIMER_MSEC_IRQ 0# define TIMER_MSEC_IRQ_INTERRUPT_CONTROLLER_ID 0# define TIMER_MSEC_LOAD_VALUE 49999ULL# define TIMER_MSEC_MULT 0.0010# define TIMER_MSEC_NAME "/dev/Timer_Msec"# define TIMER_MSEC_PERIOD 1# define TIMER_MSEC_PERIOD_UNITS "ms"# define TIMER_MSEC_RESET_OUTPUT 0# define TIMER_MSEC_SNAPSHOT 1# define TIMER_MSEC_SPAN 32# define TIMER_MSEC_TICKS_PER_SEC 1000u# define TIMER_MSEC_TIMEOUT_PULSE_OUTPUT 0# define TIMER_MSEC_TYPE "altera_avalon_timer"
# define ALT_MAX_FD 4# define ALT_SYS_CLK none# define ALT_TIMESTAMP_CLK TIMER_MSEC
At program start i use alt_timestamp_start() once.
Afterwards i do multiple read outs of alt_timestamp().
Expected behaviour:
I though the value alt_timestamp() should increase every millisec by one.
That means i should reach the limits of the 32bit timer after 49 days.
Observed behaviour:
The value of alt_timestamp() reaches the limits of 32bit after approximately 90 seconds.
Do anybody have an explanation why alt_timestamp() is so fast?
Is my understanding of the interval timer totally wrong?
What perhaps is the best way to implement a 32bit millisec clock in the nios (i would like to have a clock that can be accessed like this in code: t = GetMillisecClock())?
FredFlintstone
Well 90 * 50000000 is 0x10c388d00 so what you have generated is a counter clocked by the 50MHz input clock that would generate an interrupt every millisecond.
What you want to do is write a bit of vhld to divide sys_clk by 50, count those pulses, and make the 32bit value available to the bios cpu.
When I looked at the altera supplied 'timer' blocks, none of them do that!
In fact, IIRC, the timers are based on some 16bit vhdl so also require a significant number of instructions (and avalon accesses) to get a timestamp value.
For really fast timestamps, the counter value could be made the result of a custom instruction - so be read in a single clock and without a data delay. The fastest avalon cycle is (probably) 3 clocks + the 2 clock data delay.
If your application structure allows it, you could use the 1ms interrupt from the timer to update a counter variable. Then your GetMillisecClock() would simply read that variable.
@dsl:
Hey dsl!
Thanks for your fast reply.
--- Quote Start ---
--- Quote End ---
Grrr, and i thought creating a 32bit millisec clock would be a piece of cake and i could do it from sopc builder.
I was already thinking about that what you suggested: creating my own 32bit millisec clock via vhld (ok, i don't like vhdl - i prefer the schematic mode). But how would you make the 32bit value available to the bios(?) cpu? Via pio? Or is there a better way?
--- Quote Start ---
--- Quote End ---
I would like to understand this quoted phrase, but i cannot figure out where the "90" comes from. Could you explain this to me - perhaps i am having a mental blackout.
Thanks for sharing your experience
FredFlintstone
@Cris:
Hi Cris!
Yes, doing the GetMillisecClock() thing via interrupt is a good idea. But i am still astonished, that this alt_timestamp() stuff does not deliver the results that i would expect. Perhaps i only have the wrong mental links to the word "timestamp".
Best regards
FredFlintstone
--- Quote Start ---
@dsl:
--- Quote End ---
It's the 90 seconds you mentioned.
This means that 50M increments/sec after 90 sec will overflow the 32bit timer counter.
@Cris:
LOL. Ok, that was my mental blackout. I was only checking the nios defines for finding the "90". I should have checked my own text...
Ok, now i understand the calculation by dsl:
90sec * 50000000clocks/sec = 4500000000counts = 0x10C388D00 which does not fit into 32bit.
Got it.
Thanks again
FredFlintstone
Possibly he easiest way to read the 32bit counter is from a custom instruction!
But you'll probably need a simple avolon pio slave for something - and making it return the counter value is then fairly easy.
It is rather surprising that none of the Altera timer blocks contain a scaled 32bit up-counter.
@dsl:
--- Quote Start ---
--- Quote End ---
Yes, a scaled 32bit up-counter is exactly what i am missing in the sopc builder (is there some Altera wishlist?).
Right now i am trying to abuse a performance counter for my GetMillisecClock() purpose. Hope this will work...
Best regards
FredFlintstone
The HAL functions for the 'performance' counters take a lot of clock cycles ...
This may not matter for you, I got out HW chaps to put in 32bit counters for sys_clk itself and 1ms derived from it.
(And anther derived from an asynchronous 8MHz network clock they they forgot to synchronise to sys_clk before counting.)
@dsl:
My GetMillisecClock() from the performance counter works well. Ok, it may take a lot of clock cycles to do this, but at the moment this isn't crucial.
--- Quote Start ---
--- Quote End ---
Could you explain this a little bit further to me? I couldn't follow that.
Thanks and regards
FredFlintstone
... and make the values accessible as an Avalon MM slave.
I'm a software engineer, I don't write vhdl :-)
Actually I'm playing with some custom instructions at the moment.
The combinatorial crc_step() function seems to work fine.
Now trying to use a single instruction for bwap_32(), bwap_16() and some other transforms using the 'cB' field to select the transform.
Ok, the task is still to get some function like GetMillisecClock() working.
Perhaps assigning the created interval timer to the system clock timer in the BSP will do the trick (instead of assigning it to the timestamp timer).
I am not really sure what kind of functions do need the system clock timer. Perhaps somebody can enlighten me?
I even stumbled over a function called alt_nticks(). Maybe this could work...
At the moment it simply returns
1 if alt_sys_init() was not called
and
0 if alt_sys_init() was called.
(From some Altera pdf: It returns zero if there is no system
clock available.)
Would alt_nticks() work as a GetMillisecClock()?
Ok, now it works.
I recreated the interval timer as in the sopc builder as 32bit/1millisec "full featured" and assigned it as system timer in the BSP editor.
Now the function alt_nticks() returns the number of elapsed system clock ticks since reset.
That is all i wanted...
