build uclinux error
THANKS
I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busybox-20060320.tar.bz2,uClibc-20060320.tar.bz2 AND buildroot-20060320.tar.bz2
,then I place this files in ~/download instead of WGET commond.
COULD YOU HELP HOW TO MODIFY THE BUID FILE:
# !/bin/bash# rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source
cd ~/download
mkdir mx140
cd mx140# convert the crlf with unzip -a
echo "prepare kernel source"
unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix
cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~
cd ~/linux-2.6.x
patch -p0 <~/download/kernel.diff
cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains
mkdir ~/apps
cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps
cd ~/apps
patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source
cd ~/download
echo "prepare uClinux-dist source"
wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2
cd ~
tar jxf ~/download/uClinux-dist-20051110.tar.bz2
cd ~/uClinux-dist
patch -p0 <~/download/uClinux-dist.diff
touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab# download buildroot snapshot
cd ~/download
SNAPSHOT=20060320
rm -f buildroot-snapshot.tar.bz2 uClibc-snapshot.tar.bz2 busybox-snapshot.tar.bz2 # wget -N http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2)# wget -N http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2 (http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2)# wget -N http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2
wget -N http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2
wget -N http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2
wget -N http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2
ln -s buildroot-$SNAPSHOT.tar.bz2 buildroot-snapshot.tar.bz2
ln -s uClibc-$SNAPSHOT.tar.bz2 uClibc-snapshot.tar.bz2
ln -s busybox-$SNAPSHOT.tar.bz2 busybox-snapshot.tar.bz2
cd ~
tar jxf ~/download/buildroot-snapshot.tar.bz2
cd ~/buildroot
ln -s ~/download dl# patches for configs, add elf2flt to busybox
patch -p0 <~/download/buildroot.diff
make oldconfig
make# clean headers for uClinux-dist
cd ~/buildroot/build_nios2/staging_dir/include/linux
rm config.h autoconf.h
touch config.h autoconf.h# prepare root fs
rm -rf ~/rootfs
mkdir ~/rootfs
cp -a ~/buildroot/build_nios2/root/* ~/rootfs
cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list
rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot
cp ~/download/inittab etc
You will need wget more files for buildroot, and take more time.
Please download the binary tools and rootfs from the nios wiki, and install them.
Then use this script to prepare the sources, and you can compile the kernel.
But I still recommand you follow the uClinux-dist approach as in the wiki.
#!/bin/bash rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source cd ~/download mkdir mx140 cd mx140# convert the crlf with unzip -a echo "prepare kernel source" unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains mkdir ~/apps cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps cd ~/apps patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source cd ~/download echo "prepare uClinux-dist source" cd ~ tar jxf ~/download/uClinux-dist-20051110.tar.bz2 cd ~/uClinux-dist patch -p0 <~/download/uClinux-dist.diff touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab
thanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the WGET in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, I found that no altera directory in the uClinux-dist\vendors\,why?
thanks!!!!
--- Quote Start ---
originally posted by nwpu_zhf2004@May 29 2006, 12:22 PM
thanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the wget in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, i found that no altera directory in the uclinux-dist\vendors\,why?
thanks!!!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15644)
--- quote end ---
--- Quote End ---
The buildroot process will wget a lot more files. So I don&#39;t suggest you run buildroot.
(My best suggestion for you)
Follow the binary toolchain and uClinux-dist as in nios wiki.
You need to download only three files with your browser,
http://nioswiki.jot.com/wikihome/operating...ios2gcc.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain/nios2gcc.tar.bz2
http://nioswiki.jot.com/wikihome/operating...ux-dist.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist.diff.gz
http://www.uclinux.org/pub/uclinux/dist/uc...0060511.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20060511.tar.bz2
I know the network speed is slow. Please be patient and read some uClinux / Linux doc. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
dear hippo,
Thank you very much, because I don&#39;t know how to do,could you give me the particular step about establish uclinux,thanks!
--- Quote Start ---
originally posted by nwpu_zhf2004@May 29 2006, 03:34 PM
dear hippo,
thank you very much, because i don&#39;t know how to do,could you give me the particular step about establish uclinux,thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15647)
--- quote end ---
--- Quote End ---
OK.
step1. Do you have altera nios dev board?
If you have one, try out the prebuild zImage, as in the wiki http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux
Step2, , download the binary tool http://nioswiki.jot.com/wikihome/operating...ios2gcc.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain/nios2gcc.tar.bz2
and install as in http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain
step3, dowload
http://www.uclinux.org/pub/uclinux/dist/uc...0060511.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20060511.tar.bz2) (take a long time)
and
Then follow
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
First i thank you very much,i want do uclinux in my own custiom board,i have not altera dev board,could you give some advice in my own custom board?
thanks!
--- Quote Start ---
originally posted by nwpu_zhf2004@May 29 2006, 03:51 PM
first i thank you very much,i want do uclinux in my own custiom board,i have not  altera dev board,could you give some advice in my own custom board?
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15649)
--- quote end ---
--- Quote End ---
That&#39;s OK.
First, you should read "before you start" in the wiki http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux
And build your nios2 hardware in sopc builder, compile to sof.
The install the binary toolchain (step2) and uClinux-dist (step3).
Now you can createt the kernel zImage,
and follow the "try out" to run it (step1),
Thanks hippo, according to you ,when i execute the following command,
cd ~
tar jxf uClinux-dist-test-20060511.tar.bz2
cd uClinux-dist-test
zcat uClinux-dist.diff.gz | patch -p0
make menuconfig
then emerging the following information in the termiinal:
[root@localhost uClinux-dist-test]# make menuconfig
config/mkconfig > config.in
make -C /home/wangdengke/uClinux-dist-test/config/scripts/lxdialog all
make[1]: Entering directory `/home/wangdengke/uClinux-dist-test/config/scripts/lxdialog&#39;
/bin/sh: line 1: cc: command not found
>> Unable to find the Ncurses libraries.
>> You must have Ncurses installed in order
>> to use &#39;make menuconfig&#39;
make[1]: *** [ncurses] Error 1
make[1]: Leaving directory `/home/wangdengke/uClinux-dist-test/config/scripts/lxdialog&#39;
make: *** [menuconfig] Error 2
pls see it ,help me!!!
--- Quote Start ---
originally posted by nwpu_zhf2004@May 29 2006, 05:57 PM
thanks hippo, according to you ,when  i execute the following command,
cd ~
tar jxf uclinux-dist-test-20060511.tar.bz2
cd uclinux-dist-test
zcat uclinux-dist.diff.gz | patch -p0
make menuconfig
[root@localhost uclinux-dist-test]# make menuconfig
make -c /home/wangdengke/uclinux-dist-test/config/scripts/lxdialog all
make[1]: entering directory `/home/wangdengke/uclinux-dist-test/config/scripts/lxdialog&#39;
>> unable to find the ncurses libraries.
>> you must have ncurses installed in order
make[1]: *** [ncurses] error 1
make[1]: leaving directory `/home/wangdengke/uclinux-dist-test/config/scripts/lxdialog&#39;
make: *** [menuconfig] error 2
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15654)
--- quote end ---
--- Quote End ---
You need ncurses lib.
If you use Fedora core, "su -" to root and run "yum install ncurses ncurses-devel" .
thanks,i don&#39;t use fedora and vmware ,i only use the red hat 9.0 on pc directly ,pls help me !!!
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15656)
--- quote end ---
--- Quote End ---
fedora core is redhat linux.
cd into your redhat CD&#39;s RedHat/RPMS ,
rpm -Uvh ncurses*.rpm
[root@localhost RPMS]# rpm -Uvh ncurses*.rpm
warning: ncurses-5.3-4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
Preparing... # ########################################## [100%]
package ncurses-5.3-4 is already installed
then i execute the command:make menuconfig
this is the information :
[wangdengke@localhost uClinux-dist-test]$ make menuconfig
/bin/sh: line 1: config.in: &#26435;&#38480;&#19981;&#22815;
make: *** [config.in] Error 1
thx!
dear all,
I executed the kernal config,the error information is below,could you help me?
[root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=cpu.ptf
no emulation specific options.
RUNNING hwselect
--- Please select which CPU you wish to build the kernel against:
(1) cpu_0 - Class: altera_nios2 Type: s Version: 5.0
Selection: 1
--- Please select a device to upload the kernel to:
(1) flash
Class: altera_avalon_cfi_flash
Selection: 1
--- Please select a device to execute kernel from:
(1) number_device_0
Class: number_device
(2) sdram
Class: altera_avalon_new_sdram_controller
Selection: 2
--- Summary using
PTF: cpu.ptf
CPU: cpu_0
Device to upload to: flash
Program memory to execute from: sdram
--- Settings written to /home/wangdengke/linux-2.6.x/arch/nios2nommu/hardware.mk
then execute :
[root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig
CHK include/linux/version.h
UPD include/linux/version.h
SYMLINK include/asm -> include/asm-nios2nommu
HOSTCC scripts/basic/fixdep
/bin/sh: line 1: gcc: command not found
make[2]: *** [scripts/basic/fixdep] Error 127
make[1]: *** [scripts_basic] Error 2
make: *** [include/linux/autoconf.h] Error 2
It looks like that you didn&#39;t select software development package during redhat linux installataion.
You need to install gcc. Try "gcc -v", if not work, use rpm to install gcc.
NOTE, you should NOT cd linux-2.6.x in uClinux-dist to build kernel.
(This is different from the old buildroot guide)
READ the WIKI, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist
You should do all the make commands in ~/uClinux-dist-test dir.
OR, you should backup your data, and reinstall fedora core 5 with software development packages selected during installation.
