THANKS
I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busybox-20060320.tar.bz2,uClibc-20060320.tar.bz2 AND buildroot-20060320.tar.bz2 ,then I place this files in ~/download instead of WGET commond. COULD YOU HELP HOW TO MODIFY THE BUID FILE: # !/bin/bash# rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source cd ~/download mkdir mx140 cd mx140# convert the crlf with unzip -a echo "prepare kernel source" unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains mkdir ~/apps cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps cd ~/apps patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source cd ~/download echo "prepare uClinux-dist source" wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2) cd ~ tar jxf ~/download/uClinux-dist-20051110.tar.bz2 cd ~/uClinux-dist patch -p0 <~/download/uClinux-dist.diff touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab# download buildroot snapshot cd ~/download SNAPSHOT=20060320 rm -f buildroot-snapshot.tar.bz2 uClibc-snapshot.tar.bz2 busybox-snapshot.tar.bz2 # wget -N http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2)# wget -N http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2 (http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2)# wget -N http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2) ln -s buildroot-$SNAPSHOT.tar.bz2 buildroot-snapshot.tar.bz2 ln -s uClibc-$SNAPSHOT.tar.bz2 uClibc-snapshot.tar.bz2 ln -s busybox-$SNAPSHOT.tar.bz2 busybox-snapshot.tar.bz2 cd ~ tar jxf ~/download/buildroot-snapshot.tar.bz2 cd ~/buildroot ln -s ~/download dl# patches for configs, add elf2flt to busybox patch -p0 <~/download/buildroot.diff make oldconfig make# clean headers for uClinux-dist cd ~/buildroot/build_nios2/staging_dir/include/linux rm config.h autoconf.h touch config.h autoconf.h# prepare root fs rm -rf ~/rootfs mkdir ~/rootfs cp -a ~/buildroot/build_nios2/root/* ~/rootfs cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot cp ~/download/inittab etcLink Copied
You will need wget more files for buildroot, and take more time.
Please download the binary tools and rootfs from the nios wiki, and install them. Then use this script to prepare the sources, and you can compile the kernel. But I still recommand you follow the uClinux-dist approach as in the wiki.#!/bin/bash
cd ~/download
mkdir mx140
cd ~/linux-2.6.x
mkdir ~/apps
cd ~/apps
cd ~/download
cd ~
cd ~/uClinux-dist
thanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the WGET in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, I found that no altera directory in the uClinux-dist\vendors\,why? thanks!!!!- Mark as New
--- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 12:22 PM thanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the wget in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, i found that no altera directory in the uclinux-dist\vendors\,why?
thanks!!!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15644)
--- quote end ---
--- Quote End --- The buildroot process will wget a lot more files. So I don't suggest you run buildroot. (My best suggestion for you) Follow the binary toolchain and uClinux-dist as in nios wiki. You need to download only three files with your browser, http://nioswiki.jot.com/wikihome/operating...ios2gcc.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain/nios2gcc.tar.bz2) http://nioswiki.jot.com/wikihome/operating...ux-dist.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist.diff.gz) http://www.uclinux.org/pub/uclinux/dist/uc...0060511.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20060511.tar.bz2) I know the network speed is slow. Please be patient and read some uClinux / Linux doc. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
dear hippo,
Thank you very much, because I don't know how to do,could you give me the particular step about establish uclinux,thanks!- Mark as New
--- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 03:34 PM dear hippo,
thank you very much, because i don't know how to do,could you give me the particular step about establish uclinux,thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15647)
--- quote end ---
--- Quote End --- OK. step1. Do you have altera nios dev board? If you have one, try out the prebuild zImage, as in the wiki http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) Step2, , download the binary tool http://nioswiki.jot.com/wikihome/operating...ios2gcc.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain/nios2gcc.tar.bz2) and install as in http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain) step3, dowload http://www.uclinux.org/pub/uclinux/dist/uc...0060511.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20060511.tar.bz2) (take a long time) and http://nioswiki.jot.com/wikihome/operating...ux-dist.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist.diff.gz) Then follow http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
First i thank you very much,i want do uclinux in my own custiom board,i have not altera dev board,could you give some advice in my own custom board?
--- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 03:51 PM first i thank you very much,i want do uclinux in my own custiom board,i have not altera dev board,could you give some advice in my own custom board?
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15649)
--- quote end ---
--- Quote End --- That's OK. First, you should read "before you start" in the wiki http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) And build your nios2 hardware in sopc builder, compile to sof. The install the binary toolchain (step2) and uClinux-dist (step3). Now you can createt the kernel zImage, and follow the "try out" to run it (step1),
Thanks hippo, according to you ,when i execute the following command,
------------------------------------ cd ~ tar jxf uClinux-dist-test-20060511.tar.bz2 cd uClinux-dist-test zcat uClinux-dist.diff.gz | patch -p0 make menuconfig then emerging the following information in the termiinal: [root@localhost uClinux-dist-test]# make menuconfig config/mkconfig > config.in make -C /home/wangdengke/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/wangdengke/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: line 1: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/wangdengke/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2 [root@localhost uClinux-dist-test]# pls see it ,help me!!!- Mark as New
--- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 05:57 PM thanks hippo, according to you ,when i execute the following command,
cd ~
tar jxf uclinux-dist-test-20060511.tar.bz2
cd uclinux-dist-test
zcat uclinux-dist.diff.gz | patch -p0
make menuconfig
[root@localhost uclinux-dist-test]# make menuconfig
make -c /home/wangdengke/uclinux-dist-test/config/scripts/lxdialog all
make[1]: entering directory `/home/wangdengke/uclinux-dist-test/config/scripts/lxdialog'
>> unable to find the ncurses libraries.
>> you must have ncurses installed in order
make[1]: *** [ncurses] error 1
make[1]: leaving directory `/home/wangdengke/uclinux-dist-test/config/scripts/lxdialog'
make: *** [menuconfig] error 2
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15654)
--- quote end ---
--- Quote End --- You need ncurses lib. If you use Fedora core, "su -" to root and run "yum install ncurses ncurses-devel" .
thanks,i don't use fedora and vmware ,i only use the red hat 9.0 on pc directly ,pls help me !!!
--- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 06:14 PM thanks,i don't use fedora and vmware ,i only use the red hat 9.0 on pc directly ,pls help me !!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15656)
--- quote end ---
--- Quote End --- fedora core is redhat linux. cd into your redhat CD's RedHat/RPMS , rpm -Uvh ncurses*.rpm
[root@localhost RPMS]# rpm -Uvh ncurses*.rpm
warning: ncurses-5.3-4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e Preparing... # ########################################## [100%] package ncurses-5.3-4 is already installed then i execute the command:make menuconfig this is the information : [wangdengke@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in /bin/sh: line 1: config.in: 权限不够 make: *** [config.in] Error 1 [wangdengke@localhost uClinux-dist-test]$ thx!- Mark as New
dear all,
I executed the kernal config,the error information is below,could you help me? [root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=cpu.ptf no emulation specific options. RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu_0 - Class: altera_nios2 Type: s Version: 5.0 Selection: 1 --- Please select a device to upload the kernel to: (1) flash Class: altera_avalon_cfi_flash Size: 8388608 bytes Selection: 1 --- Please select a device to execute kernel from: (1) number_device_0 Class: number_device Size: 4 bytes (2) sdram Class: altera_avalon_new_sdram_controller Size: 8388608 bytes Selection: 2 --- Summary using PTF: cpu.ptf CPU: cpu_0 Device to upload to: flash Program memory to execute from: sdram --- Settings written to /home/wangdengke/linux-2.6.x/arch/nios2nommu/hardware.mk then execute : [root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig no emulation specific options. CHK include/linux/version.h UPD include/linux/version.h SYMLINK include/asm -> include/asm-nios2nommu no emulation specific options. HOSTCC scripts/basic/fixdep /bin/sh: line 1: gcc: command not found make[2]: *** [scripts/basic/fixdep] Error 127 make[1]: *** [scripts_basic] Error 2 make: *** [include/linux/autoconf.h] Error 2- Mark as New
It looks like that you didn't select software development package during redhat linux installataion.
You need to install gcc. Try "gcc -v", if not work, use rpm to install gcc. NOTE, you should NOT cd linux-2.6.x in uClinux-dist to build kernel. (This is different from the old buildroot guide) READ the WIKI, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist) You should do all the make commands in ~/uClinux-dist-test dir.- Mark as New
OR, you should backup your data, and reinstall fedora core 5 with software development packages selected during installation.
