drivers on uclinux
If i make a vga ip as the Avalon interface with the verilog,and the uliux support the vga driver,so i want to test this ip on uclinux.what i should do? I don't know how to connact the ip with uclinux?
--- Quote Start ---
originally posted by feng8126@Jan 4 2007, 08:01 PM
if i make a vga ip as the avalon interface with the verilog,and the uliux support the vga driver,so i want to test this ip on uclinux.what i should do? i don't know how to connact the ip with uclinux?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20352)
--- quote end ---
--- Quote End ---
You will need a frame buffer driver, see
http://nioswiki.jot.com/wikihome/operating...nux/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/framebuffer)
