12748 Discussions
elf2flash can't find boot copier
I just installed Quartus II 3.0 (yes, the old version) alongside my existing Quartus II 4.0 and Nios II IDE installations. Since then, building any software project in N2IDE produces this error:
Kind Status Priority Description Resource In Folder Location
Error *** [ext_flash.flash] Error 5 HelloWorld_altera
Error 05 PM - (SEVERE) elf2flash: Error generating Flash file, exiting[Aug 31, 2004 1] HelloWorld_altera line 46
Error 05 PM - (SEVERE) elf2flash: Error reading boot copier[Aug 31, 2004 1] HelloWorld_altera line 46
Error 05 PM - (SEVERE) elf2flash: Read error: File not found: /boot_loader_cfi.srec[Aug 31, 2004 1] HelloWorld_altera line 46
The file in question, boot_loader_cfi.srec, does exist; it's in C:\altera\kits\nios2\components\altera_nios2. My SOPC_KIT_NIOS2 and SOPC_BUILDER_PATH are both set to C:\altera\kits\nios2. In the Nios II IDE Window -> Preferences dialog, the Nios II Kit Location option is set to "Use SOPC_KIT_NIOS2 environment variable to find Nios II tools" and Quartus II Location is set to C:\quartus, where Quartus II 4.0 is installed.
I need to have both versions of Quartus installed in order to do testing.
Any idea what's going on here?
I looked in Eclipse's workspace/.metadata/.log file, but there was nothing interesting there.
I tried specifying the Nios II Kit Location and Cygwin Tools Location directly, but that had no effect.
chances are the quartus root dir is mixed up.
make sure you run the latest version of Quartus, then run the IDE.
It's a path thing for sure.
SOPC builder has changed a bit from 3.0 to 4.0 sp1, but the IDE is part of Nios II, so I'll have to see what it relies on.
Kerri's suggestion about running the 4.0 Quartus before running the IDE is a good one. The mere act of laucnhing and quitting Quartus will globally update QUARTUS_ROOTDIR. Even though you tell the IDE to look in c:\quartus the make process may somehow be getting a QUARTUS_ROOTDIR that points to the 3.0 install.
OK, tried that. Now I get this error when building a hello_world project for the std_1s10ES platform:
Error *** No rule to make target `C:/components/altera_hal/build/app.mk'. Stop. HelloWorld_altera
Error C:/components/altera_hal/build/app.mk: No such file or directory makefile HelloWorld_altera/Debug line 58
It looks like what should come between "C:/" and "components/altera_hal/build/app.mk" is missing: "altera/kits/nios2".
I then created a new application in the IDE (hello_world for std_1s10ES), built it, and got both the error above and the boot loader error I first reported here.
Here are some environment variables (after running Quartus and the IDE):
ALTERA_ARM9GP_ROOT=c:/altera/kits/xa/bin/arm-gnupro
ALTERA_ARM9GP_VER=arm9-020528
DDR_SDRAM_v1.2.1_ROOTDIR=C:\altera\megacore\ddr_sdram-v1.2.0
LMC_HOME=C:\quartus\eda\sim_lib\excalibur\swift
MG_LIB=C:\quartus\eda\sim_lib\excalibur\stripe_model_nt\modelgen\manager\WinNT\M
MG_MODEL_PATH=C:\quartus\eda\sim_lib\excalibur\stripe_model_nt\modelgen\models
MG_MODEL_REV=r0
Path=C:\Python23\.;C:\Tcl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32
\Wbem;C:\Perl\bin\;C:\Program Files\Common Files\Sonic Shared;C:\quartus\bin;C
quartus\eda\sim_lib\excalibur\swift\lib\pcnt.lib;c:\altera\excalibur\sopc_builde
r\cygwin\bin;c:\altera\excalibur\sopc_builder\cygwin\contrib\bin;C:\quartus\bin;
C:\Impulse\CoDeveloper\Libraries
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.tcl;.pyc;.pyo;.pyw;.py
;.pys
QESS_PLATFORM=bin
QESS_ROOTDIR=C:\quartus
QUARTUS_4_ROOTDIR=C:\quartus
QUARTUS_ROOTDIR=C:\quartus
SOPC_BUILDER_PATH=C:\altera\megacore\pci32_nios_target-v1.4.0\lib_time_limited\s
opc_builder+C:\altera\megacore\pci32_nios_target-v1.4.0\lib\sopc_builder+C:\alte
ra\megacore\ddr_sdram-v2.2.0\lib\sopc_builder+c:\MegaCore\ddr_sdram-v2.2.0\lib\s
opc_builder+c:\altera\kits\nios2
SOPC_KIT_NIOS2=c:\altera\kits\nios2
VIP_MODELS_DIR=C:\altera\megacore\stratix_pci_pro_kit-v1.0.0\sim_lib\VisualIP;C
\altera\megacore\ddr_sdram-v1.2.0\sim_lib\VisualIP
In the Window -> Preferences dialog, the "Effective PATH" is:
C:\altera\kits\nios2\bin;C:\altera\kits\nios2\bin\nios2-gnutools\H-i686-pc-cygwin\bin;C:\altera\kits\nios2\bin\fs2\bin;C:\quartus\bin;C:\quartus\bin\cygwin\bin;C:\Python23\.;C:\Tcl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Perl\bin\;C:\Program Files\Common Files\Sonic
I just closed Quartus 4 and the IDE, then restarted the IDE and tried to build some projects:
Error in build: (Exec error:Launching failed)
In eclipse/.metadata/.log:
!ENTRY org.eclipse.cdt.core 4 4 Sep 03, 2004 15:48:26.52 !MESSAGE Error !STACK 0 java.lang.NullPointerException     at com.altera.ide.core.builder.AlteraGeneratedMakefileBuilder.invokeMake(AlteraGeneratedMakefileBuilder.java:483)     at com.altera.ide.core.builder.AlteraGeneratedMakefileBuilder.incrementalBuild(AlteraGeneratedMakefileBuilder.java:298)     at com.altera.ide.core.builder.AlteraGeneratedMakefileBuilder.managedBuild(AlteraGeneratedMakefileBuilder.java:187)     at com.altera.ide.core.builder.AlteraGeneratedMakefileBuilder.build(AlteraGeneratedMakefileBuilder.java:157)     at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:427)     at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1006)     at org.eclipse.core.runtime.Platform.run(Platform.java:413)     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:125)     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:181)     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:191)     at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:151)     at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1006)     at org.eclipse.core.runtime.Platform.run(Platform.java:413)     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:165)     at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:265)     at org.eclipse.core.internal.resources.Project.build(Project.java:85)     at org.eclipse.ui.actions.BuildAction.invokeOperation(BuildAction.java:156)     at org.eclipse.ui.actions.WorkspaceAction.execute(WorkspaceAction.java:122)     at org.eclipse.ui.actions.WorkspaceAction$1.execute(WorkspaceAction.java:279)     at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:71)     at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1595)     at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:85)     at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:101)
Then I did a "Rebuild" of a project. Now, building projects only gives me the boot loader error, not the mysterious "(Exec error:Launching failed)" nor the app.mk file-not-found problem.
