Hi, All!
I use inetd & (how it is written in nioswiki) and the ftpd service work fine (about 2-2.5MB/s), but i am not able to perform dir or list - listing files of actual directory. Could you tell me why ? What could be set in inetd.conf or ftpd...? Thank you very much. Jan Naceradsky, Czech RepublicLink Copied
hi naceradsky,
I've got the same problem... What board do you use ?- Mark as New
I use the Stratix II DSP Development Board - DK-DSP-EP2S180N now and before this on CycloneII NiosII development board i had had the same problem. Jan- Mark as New
it's not a board problem.
add the ls from the busybox and it works ;)- Mark as New
I understand, that it si not a board problem, but i have add ls in Busybox in Coreutils, but it doesnt work ... i use sash shell.
Jjan- Mark as New
is there a "ls" in your /bin/ folder?
--- Quote Start --- Ii use sash shell.Jjan --- Quote End --- sash provides ls as an internal command, so even if "ls" works in a script or on the command line, ftp needs ls to be a file based command (in /bin), (e.g. activated in busybox). BTW sash is depreciated, you should convert to msh (see Wiki). -Michael
I have ls in /bin, but it is only link .... but when i use busybox, every commands, which i add in busybox, are links.
Dont work in sash or msh shell, why ? Like ftp client use totalcommander. Jan- Mark as New
--- Quote Start --- I have ls in /bin, but it is only link .... but when i use busybox, every commands, which i add in busybox, are links. --- Quote End --- All busybox generated commands are links to busybox. That is the "busybox trick". You don't need to bother, it just works (though slow, see the Wiki on "Haserl"). --- Quote Start --- Dont work in sash or msh shell, why ? --- Quote End --- I don't understand what you mean. --- Quote Start --- Like ftp client use totalcommander. --- Quote End --- You might try some decent Linux program, too, but of course TotalCommander should work if ls is decently enabled. -Michael
Sorry, I mean, that ls was add in sash shell - it doesnt work and when i used msh shell with ls, it doesnt work too.
I try any other linux program... I can try hush shell with ls in busybox. Jan- Mark as New
what do you mean by "it does not work" Does ls work with the shell ? The shell has noting to do with if ls works for ftp or not.
-Michael- Mark as New
ls in all shell work. Listing in ftp client doesn´t work. Maybe the error is in other parts of uClinux. Jan- Mark as New
--- Quote Start --- ls in all shell work. Listing in ftp client doesn´t work. --- Quote End --- This is a well known problem. many shells have ls as a built-in command. ftp needs ls as an executable (or link to an executable) in (if I remember correctly) "/bin. try /bin/ls and /bin/ls -l does this work ? --- Quote Start --- Maybe the error is in other parts of uClinux. --- Quote End --- Unlikely ! -Michael
It works ! :-)
Jan- Mark as New
/bin/ls
and /bin/ls -l works. Ftp dir (listing) doesn´t. Jan- Mark as New
are you trying to use the command "dir" to show the listing of the ftp?
In C:\Windows\system32\ftp.exe the command ls in ok, but only file or directory name without extended info about files. Dir or ls -l does not list anything.
Jan
