公告
12748 讨论
inetd or ftpd does not display file listing of directory
名誉分销商 II
2,142 次查看
Hi, All!
I use inetd & (how it is written in nioswiki) and the ftpd service work fine (about 2-2.5MB/s), but i am not able to perform dir or list - listing files of actual directory.
Could you tell me why ? What could be set in inetd.conf or ftpd...?
Thank you very much.
Jan Naceradsky, Czech Republic
0 项奖励
16 回复数
名誉分销商 II
1,134 次查看
hi naceradsky,
I've got the same problem...
What board do you use ?
0 项奖励
名誉分销商 II
1,134 次查看
I use the Stratix II DSP Development Board - DK-DSP-EP2S180N now and before this on CycloneII NiosII development board i had had the same problem.
Jan
0 项奖励
名誉分销商 II
1,134 次查看
it's not a board problem.
add the ls from the busybox and it works ;)
0 项奖励
名誉分销商 II
1,134 次查看
I understand, that it si not a board problem, but i have add ls in Busybox in Coreutils, but it doesnt work ... i use sash shell.
Jjan
0 项奖励
名誉分销商 II
1,134 次查看
is there a "ls" in your /bin/ folder?
0 项奖励
名誉分销商 II
1,134 次查看
--- Quote Start ---
Ii use sash shell.Jjan
--- Quote End ---
sash provides ls as an internal command, so even if "ls" works in a script or on the command line, ftp needs ls to be a file based command (in /bin), (e.g. activated in busybox).
BTW sash is depreciated, you should convert to msh (see Wiki).
-Michael
0 项奖励
名誉分销商 II
1,134 次查看
I have ls in /bin, but it is only link .... but when i use busybox, every commands, which i add in busybox, are links.
Dont work in sash or msh shell, why ?
Like ftp client use totalcommander.
Jan
0 项奖励
名誉分销商 II
1,134 次查看
--- Quote Start ---
--- Quote End ---
All busybox generated commands are links to busybox. That is the "busybox trick". You don't need to bother, it just works (though slow, see the Wiki on "Haserl").
--- Quote Start ---
--- Quote End ---
I don't understand what you mean.
--- Quote Start ---
--- Quote End ---
You might try some decent Linux program, too, but of course TotalCommander should work if ls is decently enabled.
-Michael
0 项奖励
名誉分销商 II
1,134 次查看
Sorry, I mean, that ls was add in sash shell - it doesnt work and when i used msh shell with ls, it doesnt work too.
I try any other linux program...
I can try hush shell with ls in busybox.
Jan
0 项奖励
名誉分销商 II
1,134 次查看
what do you mean by "it does not work" Does ls work with the shell ? The shell has noting to do with if ls works for ftp or not.
-Michael
0 项奖励
名誉分销商 II
1,134 次查看
ls in all shell work. Listing in ftp client doesn´t work.
Maybe the error is in other parts of uClinux.
Jan
0 项奖励
名誉分销商 II
1,134 次查看
--- Quote Start ---
--- Quote End ---
This is a well known problem. many shells have ls as a built-in command. ftp needs ls as an executable (or link to an executable) in (if I remember correctly) "/bin.
try
/bin/ls
and
/bin/ls -l
does this work ?
--- Quote Start ---
--- Quote End ---
Unlikely !
-Michael
0 项奖励
名誉分销商 II
1,134 次查看
It works ! :-)
Jan
0 项奖励
名誉分销商 II
1,134 次查看
/bin/ls
and
/bin/ls -l
works.
Ftp dir (listing) doesn´t.
Jan
0 项奖励
名誉分销商 II
1,134 次查看
are you trying to use the command "dir" to show the listing of the ftp?
0 项奖励
名誉分销商 II
1,134 次查看
In C:\Windows\system32\ftp.exe the command ls in ok, but only file or directory name without extended info about files. Dir or ls -l does not list anything.
Jan
0 项奖励
回复
