kernal build error
dear hippo,
Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i
select the ALTERA JTAG UARTsupport,and the nios serial support, then compile :
[wangzhiwunpu@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
no emulation specific options.
CHK include/nios2_system.h
CHK include/linux/version.h
SPLIT include/linux/autoconf.h -> include/config/*
CC init/main.o
CHK include/linux/compile.h
CC init/do_mounts.o
LD init/mounts.o
LD init/built-in.o
CHK usr/initramfs_list
CC arch/nios2nommu/kernel/signal.o
CC arch/nios2nommu/kernel/setup.o
CC arch/nios2nommu/kernel/start.o
arch/nios2nommu/kernel/start.c: In function `main':
arch/nios2nommu/kernel/start.c:523: warning: label `badshiftci_label' defined but not used
LD arch/nios2nommu/kernel/built-in.o
CC kernel/printk.o
CC kernel/exit.o
CC kernel/signal.o
CC kernel/sys.o
CC kernel/power/console.o
LD kernel/power/built-in.o
CC kernel/acct.o
LD kernel/built-in.o
CC fs/open.o
CC fs/dquot.o
CC fs/devpts/inode.o
LD fs/devpts/devpts.o
LD fs/devpts/built-in.o
CC fs/proc/array.o
CC fs/proc/proc_tty.o
CC fs/proc/proc_misc.o
LD fs/proc/proc.o
LD fs/proc/built-in.o
LD fs/built-in.o
CC drivers/char/mem.o
drivers/char/mem.c: In function `mmap_kmem':
drivers/char/mem.c:276: warning: cast to pointer from integer of different size
CC drivers/char/tty_io.o
In file included from include/linux/selection.h:11,
from drivers/char/tty_io.c:104:
include/linux/vt_buffer.h:19:21: asm/vga.h: No such file or directory
make[2]: *** [drivers/char/tty_io.o] Error 1
make[1]: *** [drivers/char] Error 2
make: *** [drivers] Error 2
You should not follow the old buildroot guide. Do not cd linux-2.6.x to make kernel.
DO NOT MIX UP.
Follow the step in the new wiki,
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
dear hippo, when i process the step according to this command:
Then <exit> <exit> <yes> .
(see LinuxConfig for kernel config items)
# compile kernel and apps
make
make romfs# rebuild kernel for initramfs
make linux image
when execute the command :
[wangzhiwunpu@localhost uClinux-dist-test]$ make
sl -lcrypt -lutil -lc
xloader.c:31:29: asm/uCbootstrap.h: No such file or directory
xloader.c:61: error: syntax error before "m"
xloader.c:61: warning: data definition has no type or storage class
xloader.c:67: error: syntax error before "header"
xloader.c:67: warning: data definition has no type or storage class
xloader.c:98: error: syntax error before "program"
xloader.c:99: error: syntax error before "program2"
xloader.c:100: error: syntax error before "ramload"
xloader.c:101: error: syntax error before "setbenv"
xloader.c: In function `_bsc1&#39;:
xloader.c:108: error: syntax error before &#39;*&#39; token
xloader.c:114: error: syntax error before &#39;{&#39; token
xloader.c:191: error: parameter `err&#39; is initialized
xloader.c:195: error: syntax error before "c"
xloader.c:367: error: redefinition of parameter &#39;i&#39;
xloader.c:190: error: previous definition of &#39;i&#39; was here
xloader.c:368: error: parameter `bytes_read&#39; is initialized
xloader.c:375: error: syntax error before "if"
xloader.c:629: error: syntax error before "for"
xloader.c:647: error: redefinition of parameter &#39;statbuf&#39;
xloader.c:366: error: previous definition of &#39;statbuf&#39; was here
xloader.c:648: error: redefinition of parameter &#39;filesize&#39;
xloader.c:367: error: previous definition of &#39;filesize&#39; was here
xloader.c:648: error: redefinition of parameter &#39;i&#39;
xloader.c:367: error: previous definition of &#39;i&#39; was here
xloader.c:648: error: redefinition of parameter &#39;n&#39;
xloader.c:367: error: previous definition of &#39;n&#39; was here
xloader.c:649: error: redefinition of parameter &#39;percent&#39;
xloader.c:370: error: previous definition of &#39;percent&#39; was here
xloader.c:650: error: redefinition of parameter &#39;ferror_image&#39;
xloader.c:371: error: previous definition of &#39;ferror_image&#39; was here
xloader.c:653: error: syntax error before "if"
make[2]: *** [xloader] Error 1
make[2]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test/user/boottools&#39;
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test/user&#39;
make: *** [subdirs] Error 1
thanks!!
1. Did you apply the Nios2 patches to uClinux-dist-test?
cd ~ tar jxf uClinux-dist-test-20060511.tar.bz2 cd uClinux-dist-test zcat uClinux-dist.diff.gz | patch -p0
2. when you run "make menuconfig" , check if you have the correct target?
Vendor/Product Selection --->
--- Select the Vendor you wish to target
(Altera) Vendor
--- Select the Product you wish to target
(nios2nommu) Altera Products
then <exit>
3. still in "make menuconfig", try restore to default setting,
Kernel/Library/Defaults Selection --->
(linux-2.6.x) Kernel Version
(None) Libc Version
[*] Default all settings (lose changes)
[ ] Customize Kernel Settings
[ ] Customize Vendor/User Settings
[ ] Update Default Vendor Settings
4. "make" again.
dear hippo,
Thank you, when I do according to you i could do next commands successfully,
-------------------------------------# compile kernel and apps
make
make linux image
---------------------------------sucessed
then i do :
http://nioswiki.jot.com/wikihome/operating...x/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux
/cygdrive/c/altera
[sopc builder]$ nios2-download -g zImage...
Using cable "byteBlaster II [LPT1]",device1,instance 0x00
pausing target processor:OK
downloaded 745KB in 17.9s<42.1KB/s>
Verify failed
Leaving target processor pauseed
cygdrive/c/altera
thanks
It may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on IDE/HAL .
2. byteblaster is not stable, altera recommend usb blaster for nios2 download.
Try add termination to jtag signal on your board.
If I were you, I wouldn&#39;t try to jump right into uCLinux on a new board. I would start small, with something like "Hello World" or "Count Binary". Be sure that all of your major interfaces (flash, RAM, etc.) function before moving on to anything more complex. There&#39;s even a provided example for testing the flash and SDRAM, though you&#39;ll have to modify it, slightly, to get it to fully test your system.
It&#39;s like building a wall. You wouldn&#39;t want to add another layer of bricks to something that isn&#39;t solid, would you?
- slacker
--- Quote Start ---
originally posted by hippo@May 31 2006, 11:15 AM
it may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on ide/hal .
  try add termination to jtag signal on your board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15704)
--- quote end ---
--- Quote End ---
You have 8MB sdram,
you should set boot loader offset to 5M in kernel config. http://nioswiki.jot.com/wikihome/operating...nux/linuxconfig (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxconfig
cd ~/uClinux-dist-test
make menuconfig
(None) Libc Version
[ ] Default all settings (lose changes)
[*] Customize Kernel Settings
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
If you use DEII with 8M sdram, change the link address of the uncompress loader,
Processor type and features-->(0x00500000) Link address offset for booting.
The zImage load address is ( your sdram base address + link address offset ) . The zImage boot loader does not relocate itself.[/b]
--- Quote End ---
Then "make" again.
--- Quote Start ---
--- Quote End ---
Thanks,I am sure the FLASH and the SDRAM is no problem ,because i tested the hardware and can run UCOS/2 application and other programs.
the flash(8MB) base address is 0x000000,the sdram(8MB) base address is 0x800000,so i set the zImage load address :0x500000+0x800000=0x0d00000,
and then make ,still has the same problem.
why set the link address offset 0x500000?
thanks
--- Quote Start ---
originally posted by nwpu_zhf2004@May 31 2006, 03:40 PM
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
if you use deii with 8m sdram, change the link address of the uncompress loader,
processor type and features-->(0x00500000) link address offset for booting.
the zimage load address is ( your sdram base address + link address offset ) . the zimage boot loader does not relocate itself.
--- Quote End ---
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15713)</div>
[/b]
--- Quote End ---
Did you "make linux image" ?
You should set Link address offset for booting to 0x500000, not 0xd00000 .
Kernel config will add up with sdram start.
During nios2-download , what is the load address show up?
try,
nios2-linux-uclibc-objdump -h zImage
it should display, .text start from VMA/LMA 0xd00000 .
Thank you very much! you are so intelligent !
I have successed!
thank you very much again!!!
for these command:
i want to known the where the uClinux-dist.diff.gz i should palce!
the uClinux-dist-test dir or anywhere???
--- Quote Start ---
originally posted by iriver@Jun 4 2006, 09:14 PM
for these command:
      cd uclinux-dist-test
zcat uclinux-dist.diff.gz | patch -p0
i want to  known the where the uclinux-dist.diff.gz i should palce!
the uclinux-dist-test dir or anywhere???
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15882)
--- quote end ---
--- Quote End ---
You can place it in uClinux-dist-test,
but anywhere should work if you give the path.
hi hippo:
I set Link address offset for booting to 0x500000,
but,when i nios2-download,the load address 0x00D000000 show up!
I don&#39;t know why?
You problem is cuased by the sof. The sof included in the DE2 disc (v1.3,v1.4,v1.5) is no good. You should recompile the sof or use older sof, the one attached in the wiki is v1.1 .
--- Quote Start ---
I use the .sof file you offer, and i download my linux.but i can not work.Then i download the zImage you offer,it can work.So i think the problem may not be cansed by the sof.
Please try "make clean",
Start the make all over again. with "make menuconfig" to default,
I try again as you tell me,but there is also the problem!Could you give me a DE2_NET project? This is my EMAIL:li8126@sina.com
Thanks!!
I follow the step in the new wiki,
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist
Where you guys getting this error:
I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer
but I ran into this error when trying to run make in the uClinux-dist/
fs/buffer.c: In function `__find_get_block_slow&#39;:
fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3)
LD fs/built-in.o
from drivers/char/tty_io.c:103:
include/linux/vt_buffer.h:18:21: asm/vga.h: No such file or directory
make[3]: *** [drivers/char/tty_io.o] &#38169;&#35823; 1
make[2]: *** [drivers/char] &#38169;&#35823; 2
make[1]: *** [drivers] &#38169;&#35823; 2
make[1]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x&#39;
make: *** [linux] &#38169;&#35823; 1
--- Quote Start ---
originally posted by liuxiaoping@Apr 2 2007, 08:14 PM
i follow the step in the new wiki,
where you guys getting this error:
i tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer
but i ran into this error when trying to run make in the uclinux-dist/
fs/buffer.c: in function `__find_get_block_slow&#39;:
ld fs/built-in.o
cc drivers/char/tty_io.o
in file included from include/linux/selection.h:11,
include/linux/vt_buffer.h:18:21: asm/vga.h: no such file or directory
make[1]: leaving directory `/home/nios/download/uclinux-dist/linux-2.6.x&#39;
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22732)
--- quote end ---
--- Quote End ---
You must disable these two console,
Device Drivers --> Graphics support --->
Console display driver support --->
[ ] VGA text console
< > Framebuffer Console support
