max10 RSU without nios
aiedb
초급자
897 조회수
hii
is there a documentation that show the work flow that i need in order to perform MAX10 rsu without the help of nios ii , with my discrete logic ???
레이블 (1)
0 포인트
7 응답
KalenB_Altera
직원
884 조회수
Hi Aiebd,
RSU on Max 10 has two key steps; 1) Write the new image to flash via the User Flash Memory IP (https://www.intel.com/content/www/us/en/docs/programmable/683180/18-0/on-chip-flash-core-references.html) and 2) Identifying to the configuration system what CFM to use on the next nConfig and trigger reconfiguration via the Dual Configuration IP (https://www.intel.com/content/www/us/en/docs/programmable/683865/current/dual-configuration-core-26199.html).
You could definitely use an FSM to do these operations. I hope these user guides help give you the info you need.
0 포인트
aiedb
초급자
813 조회수
hii thanks a lot for help
lets say i want to write my own fsm to trigger an rsu after writing my image to cfm0 and cfm 1/2 what are the registers that i need to work with in order to :
1- trigger the nconfig ?
2-to choose from which cfm that fpga get configured ?
0 포인트
KalenB_Altera
직원
776 조회수
Hi Aiebd,
Section 5.2 of the Dual Config IP mentions the registers and fields. Here's a link: https://www.intel.com/content/www/us/en/docs/programmable/683865/current/dual-configuration-core-memory-mapped.html
The relevant registers for your question are at word address 0 and 1. I've coped them below:
Offset R/W Width (Bits) Description
0W32
  • Bit 0—Trigger reconfiguration.
  • Bit 1—Reset the watchdog timer.
  • Bit 31:2—Reserved.
Signals are triggered at the same write cycle on Avalon® .
1W32
  • Bit 0—Trigger config_sel_overwrite value to the input register.
    • 0: Disable overwrite config_sel pin.
    • 1: Enable overwrite config_sel pin.
  • Bit 1—Writes config_sel value to the input register. Set 0 or 1 to load from configuration image 0 or 1 respectively
    • 0: Load configuration image 0.
    • 1: Load configuration image 1.
The busy signal is generated right after the write cycle, while the configuration image information is registered. Once the busy signal is high, writing to this address is ignored until the process is completed and the busy signal is de-asserted.
0 포인트
aiedb
초급자
714 조회수
hii thanks for your reply , i will try to built my own fsm and see how it will work for me
0 포인트
KennyTan_Altera
중재자
662 조회수
Do you have further question? If no, we shall close this thread.
0 포인트
aiedb
초급자
646 조회수
hii you can close thanks
0 포인트
KennyTan_Altera
중재자
621 조회수
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
0 포인트
응답
