12745 Discussions
need help for niosII 9.1 flash programmer
when I use USB-Blaster to program flash,it always stop and there are some words say:
Using cable"USB-Blaster[USB-0]",device 1,instance 0x00
Resetting and pausing target processor:FAILED
Leaving target processor paused
below is one line of red words say:
Error code:4 for command:$SOPC_KIT_NIOS2/bin/nios2-flash-programmer"E:/gmr_prog/pro_v2/flash/gmr_sys_v2_cfi_flash.flash"-base=0x200000-sidp=0x50110A0-id=0x7193BE6F-accept-bad-sysid-device=1-instance=0'-cable=USB-Blaster[USB-0]"-program-verbose
how can I resolve this problem?
thank you !
The FAILED line is the one you need to resolve, first. I've seen this is a number of cases, but it usually happens to me when I connect the clocks/resets incorrectly.
--slacker
I'm in the process of migrating a SOPC design to QSYS (using Quartus II version 11.1sp1). Doing so, I was checking that things are working as they should. When using the Flash Programmer inorder to program the flash memory device, I was getting the Error code 4 message when using the Flash Programmer:
"Error code:4 for command:..."
It turned of that in my case "faulty" connections in QSYS was causing the error message. I had connected the NiosII Processor's "jtag_debug_module_reset" to several reset ports for IP's in the QSYS design, (including the Generice tri-state controller/conduit pin sharer/conduit bridge IP modules).
Removing these connections made the error message go away. Perhaps this can be of help to others getting the same error code
saber890
I am also having the same issue .niosii processor's "jtag_debug_module_reset" we need to connect the jtag debug module ??.I removed the reset connection from NiosII Processor's "jtag_debug_module_reset" to reset ports for IP's in the QSYS design, (including the Generice tri-state controller/conduit pin sharer/conduit bridge IP modules).
but this reset connection is needed : -niosii processor's "jtag_debug_module_reset" to jtag debug module reset. ????
--- Quote Start ---
saber890
--- Quote End ---
