12745 Discussions
nios2-bsp-create-settings failed error
Hi everyone, I am getting this error when I am trying
new-> Nios II Application and BSP from Template
Compilation is successful in Quartus. But I can not create a Project in eclipse.
I am using the version 13.0sp1.
Thanks for the answers.
INFO: Finished initializing SOPC project local software IP. Total time taken = 4 seconds
INFO: Searching for BSP components with category: driver_element
INFO: Searching for BSP components with category: software_package_element
INFO: Loading drivers from ensemble report.
INFO: Finished loading drivers from ensemble report.
SEVERE: Setting does not exist for BSP: "hal.stdın".
WARNING: Tcl script "bsp-set-defaults.tcl " error: Setting does not exist for BSP: "hal.stdın".
SEVERE: Setting does not exist for BSP: "hal.max_file_descriptors".
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings failed
nios2-bsp hal . C:/altera/13.0sp1/proj_Helloworld/proj_qsys.sopcinfo --set hal.max_file_descriptors 4 --set hal.enable_small_c_library true --set hal.sys_clk_timer none --set hal.timestamp_timer none --set hal.enable_exit false --set hal.enable_c_plus_plus false --set hal.enable_lightweight_device_driver_api true --set hal.enable_clean_exit false --set hal.enable_sim_optimize false --set hal.enable_reduced_device_drivers true --set hal.make.bsp_cflags_optimization '-Os' --cpu-name nios2_qsys_0 failed
