12748 Discussions
philip lutz DE2 uclinux nios2 project , lcd16207 display
Somebody has run the philip lutz project ?
When the Makefile build de2_lcd16207 and button object modules there is some errors ( doc adjunt) ,
i need some configuration before compile these modules?
Hi candido,
In de2_lcd_16207.c, u have to change the function cleanup_module() to
void cleanup_moduel() { unregister_chrdev(MAJOR_NUMBER, DEVICE_NAME); }
And ignore the other components in that function.
i have download lcd16702.c and lcd16702.h from nios2wiki and both installed in /linux2.6/drivers/char
i have edit lcd16702.c -> cleanup function
i have edit romfs-list
nod /dev/lcd16702 666 0 0 c 250 0
nod /dev/switches ......... and others philip lutz pio drivers
make menuconfig -> customize kernel ->platform -> DE2 altera
->drivers->char->lcd16702
->drivers-misc->philip-> leds ,switches, seg7
->customize application-> hush shell and busybox
make : no errors
make linux image : no errors
i have then download the image to nios2 soft
open nios2-terminal
> hush
# echo 255 > /dev/leds_red -> no problem -> 8 leds on
# echo 255 > /dev/leds_green -> no problem
# cat /dev/switches -> no problem
# echo AAAA > dev/seg7 -> no problem
# echo "hello" > /dev/lcd16207 ->FAILED: NOTHING OCURR-> lcd with default message: Wellcome to Altera Board
¿ Some trick? I have begin studyin linux drivers oreilly book.
I have tried too with default lcd16702 uclinux-dist drivers but there is no lcd16207.h headers file in /linux/
hi Candido,
plz follow this instruction: http://alterauserforums.org/forum/showthread.php?p=72262
Thanks!
getting instrucction from nioswiki and that post about cache skip i have get run the lcd driver!
Cándido
