problem with NiosII IDE 5.1
Hi Everyone,
I have installed NiosII IDE5.1, but when I compiled any project, the following errors occurred.
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: `: No such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: "c:/altera/kits/nios2_51"`: No such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: /components/altera_hal/build/gnu_rules.mk: No such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: `: No such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: "c:/altera/kits/nios2_51"`: No such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: /components/altera_hal/build/gtf_rules.mk: No such file or directory
But I can find all the *.mk file in the corresponding directory.
Anyone help?
Thanks in advance...
I had a similar problem when direcoty have some space bar character in path name, try to see it.
--- Quote Start ---
originally posted by david_cai@Feb 14 2006, 12:49 PM
hi everyone,
    i have installed niosii ide5.1, but when i compiled any project, the following errors occurred.
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: `: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: "c:/altera/kits/nios2_51"`: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: /components/altera_hal/build/gnu_rules.mk: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: `: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: "c:/altera/kits/nios2_51"`: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: /components/altera_hal/build/gtf_rules.mk: no such file or directory
but i can find all the *.mk file in the corresponding directory.
anyone help?
thanks in advance...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12701)
--- quote end ---
--- Quote End ---
illege character
" ` " http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
And so? all ok?
I can&#39;t find any space bar in the directory path and any illegal character. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Pls tell me in detail.
Thanks very much.
I have almost find the answer throught altera website.
The following if FYI.
Problem
Why do I receive the following errors when trying to compile my Nios II project: ../app_rules.mk:152: \: No such file or directory?
Solution
You may receive the following errors when compiling a Nios® II software project if the mount point for the Cygwin toolset is not specified properly.
make -s all
"X"which cygpath.exe 2> /dev/null`" was unexpected at this time.
<Nios II install directory>/components/altera_hal/build/app_rules.mk:152: `: No such file or directory
<Nios II install directory>/components/altera_hal/build/app_rules.mk:152: "<Nios II install directory>"`: No such file or directory
<Nios II install directory>/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory
<Nios II install directory>/components/altera_hal/build/app_rules.mk:156: &#39;: No such file or directory
<Nios II install directory>/components/altera_hal/build/app_rules.mk:156: "<Nios II install directory>"`: No such file or directory
<Nios II install directory>/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory
make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk&#39;. Stop.
Build completed
If this error does occur you can specify the proper moint points by running the following three commands from a DOS prompt:
mount <Quartus® II Install directory>\bin\cygwin\ /
mount <Quartus II Install directory>\bin\cygwin\bin /usr/bin
mount <Quartus II Install directory>\bin\cygwin\lib /usr/lib
But when I run the mount command in niosII SDK, it told me that command not found...
Anyone help?
THanks a lot...
The cygwin environment is installed along with Quartus II. To me, it looks like you have a corrupt Quartus II installation. I&#39;d start with uninstalling/re-installing Quartus II.
- slacker
Dear all,
I have solved the problem... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
I would like to share it with all of you.
1. In DOS shell, change the directory as the following path:
C:\altera\quartus51sp1\bin\cygwin\bin
where the mount command exist.
2. run the following commands to specify mount point for the Cygwin toolset
Be sure that before you can execute the commands above correctly, you should login PC as an administrator.
Thanks all the help...
David
I have the same problem with NIOS 6.1
Altera can't find the files:
C:/altera/61/nios2eds/components/altera_hal/build/app_rules.mk:153: /components/altera_hal/build/gnu_rules.mk: No such file or directory
C:/altera/61/nios2eds/components/altera_hal/build/app_rules.mk:157: /components/altera_hal/build/gtf_rules.mk: No such file or directory
make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop.
Build completed in 1.139 seconds
when they are clearly there.
I tried the mount command in DOS and it replies "Device or resource busy"
I had other later versions of Quartus and Nios on this computer and that could have caused this problem. Have since uninstalled them. I did a repair re-install of quartus and a complete re-install of NIOS IDE but that didn't help.
Any suggestions?
thanks
