12748 Discussions
sshd does not work when shadow password is enabled
sshd does not work for me when shadow password is enabled.
1. I can telnet to my box as root (with shadow password enabled) ==>> username/password is valid.
2. If I disable shadow password, sshd works fine. I can login as root. ==>> the ssh keys are fine and sshd_config file is also good.
Any ideas?
I am using busybox login, shadow password. I have configured all internal APIs option in busybox.
My box runs the 2010621 tar file. I updated the ssh and busybox directories to the latest without any change in behavior. Looks like I am missing something obvious. Including a snippet of the failure from '/bin/sshd -Dde'.
I need to use shadow password for backward compatibility, so disabling shadow is not an option.
ebug1: kex: client->server aes128-ctr hmac-md5 none
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST received
WARNING: /etc/config/moduli does not exist, using fixed modulus
debug1: SSH2_MSG_KEX_DH_GEX_GROUP sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_INIT
debug1: SSH2_MSG_KEX_DH_GEX_REPLY sent
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: KEX done
debug1: userauth-request for user root service ssh-connection method none
debug1: attempt 0 failures 0
Failed none for root from 169.254.1.11 port 58277 ssh2
debug1: userauth-request for user root service ssh-connection method keyboard-interactive
debug1: attempt 1 failures 0
debug1: keyboard-interactive devs
debug1: auth2_challenge: user=root devs=
debug1: kbdint_alloc: devices ''
debug1: userauth-request for user root service ssh-connection method password
debug1: attempt 2 failures 1
Failed password for root from 169.254.1.11 port 58277 ssh2
