OpenCL* for CPU
1736 Discussions
about the performance of Intel OpenCL SDK
teng_w_
      I tested the performance between Intel OpenCL SDK and avx with multithread. I think the OpenCL sdk also using avx and multithread in the opencl driver. So the performance maybe almost equal.
But the result is the time using OpenCL  is 890ms, while the avx with multithread is 220ms. I already read the optimize notice for intel opencl sdk.  So I want to ask whether the OpenCL sdk using  avx and multithread in the driver.  or I guess the driver only using sse and multithread. that can explain the performance difference .The test env. is:
WIN7 x64 sp1
i5-4590   DDR3 8G memory dual channel.
OpenCL sdk 16.1
Thank you.
teng_w_
sorry,  the opencl sdk is intel_sdk_for_opencl_setup_6.1.0.1600
ms vs2010.
teng_w_
how can i check whether the opencl binary code after compile using avx. thank u.
the algorithm is almost like convolution filter with a kernel 7*7 size.
