OpenCL* for CPU
ioc64 merge cl source files into one spirv for x64 and x86
wisboeck__gerald
I have two opencl source files. a.cl and b.cl I can compile them both into four spirv's. Is it possible to compile both into two spirv's? I have tried to compile them into .ir's then link them into one .ir and then build again to -spirv32="end.spirv" but that didn't work...
Michael_C_Intel1
Hello GeraldW,
Thanks for the question.
Can you provide:
  • full command line(s) suggestions that coincide with your goals?
  • the full command line(s) of the case that worked.
  • the full command line(s) and output of the case that didn't work? Can you show any errors encountered?
Please see this recommendation here:
https://software.intel.com/en-us/articles/ocl-issue-reporting-guide
...This would help determine how to proceed. Thanks.
-MichaelC
