OpenCL* for CPU
is this a bug? clCreateProgramWithBinary failed from ir file
Weibin_T_
comile command:
/opt/intel/bin/icpc -g -o test  -I/opt/intel/opencl-sdk/include -L/opt/intel/opencl/lib64 -lOpenCL *.cpp
run command: ./test test.cl -debug
output:
 CL_PLATFORM_NAME:      Intel(R) OpenCL
 CL_PLATFORM_VERSION:   OpenCL 1.2 LINUX
run command: ./test test.ir
output:
 Error CL_INVALID_PROGRAM in oclLogBuildInfo Call !!!
// oclTest.cpp
#include<stdio.h>
#include <stdlib.h>
#include <memory.h>
#include <string.h>
// All OpenCL headers
#if defined (__APPLE__) || defined(MACOSX)
#include <OpenCL/opencl.h>
#else
#include <CL/opencl.h>
#endif
#define VENDOR_INTEL "Intel(R)"
cl_int oclGetPlatformID(cl_platform_id* clSelectedPlatformID)
	char chBuffer[1024];
	cl_uint num_platforms;
	cl_platform_id* clPlatformIDs;
	cl_int ciErrNum;
	*clSelectedPlatformID = NULL;
	// Get OpenCL platform count
	ciErrNum = clGetPlatformIDs (0, NULL, &num_platforms);
	if (ciErrNum != CL_SUCCESS)
		printf(" Error %i in clGetPlatformIDs Call !!!\n\n", ciErrNum);
		return -1000;
	else
		if(num_platforms == 0)
			printf("No OpenCL platform found!\n\n");
			return -2000;
		else
			// if there's a platform or more, make space for ID's
			if ((clPlatformIDs = (cl_platform_id*)malloc(num_platforms * sizeof(cl_platform_id))) == NULL)
				printf("Failed to allocate memory for cl_platform ID's!\n\n");
				return -3000;
			// get platform info for each platform and trap the NVIDIA platform if found
			ciErrNum = clGetPlatformIDs (num_platforms, clPlatformIDs, NULL);
			for(cl_uint i = 0; i < num_platforms; ++i)
				ciErrNum = clGetPlatformInfo (clPlatformIDs, CL_PLATFORM_NAME, 1024, &chBuffer, NULL);
				if(ciErrNum == CL_SUCCESS)
					if(strstr(chBuffer, VENDOR_INTEL) != NULL)
						*clSelectedPlatformID = clPlatformIDs;
						break;
			// default to zeroeth platform if NVIDIA not found
			if(*clSelectedPlatformID == NULL)
				printf("WARNING: NVIDIA OpenCL platform not found - defaulting to first platform!\n\n");
				*clSelectedPlatformID = clPlatformIDs[0];
			free(clPlatformIDs);
	return CL_SUCCESS;
char* oclLoadProgSource(const char* cFilename, size_t* szFinalLength)
	// locals
	FILE* pFileStream = NULL;
	size_t szSourceLength;
	// open the OpenCL source code file
#ifdef _WIN32   // Windows version
	if(fopen_s(&pFileStream, cFilename, "rb") != 0)
		return NULL;
#else           // Linux version
	pFileStream = fopen(cFilename, "rb");
	if(pFileStream == 0)
		return NULL;
#endif
	// get the length of the source code
	fseek(pFileStream, 0, SEEK_END);
	szSourceLength = ftell(pFileStream);
	fseek(pFileStream, 0, SEEK_SET);
	// allocate a buffer for the source code string and read it in
	char* cSourceString = (char *)malloc(szSourceLength + 1);
	if (fread((cSourceString), szSourceLength, 1, pFileStream) != 1)
		fclose(pFileStream);
		free(cSourceString);
		return 0;
	// close the file and return the total length of the combined (preamble + source) string
	if(szFinalLength != 0)
		*szFinalLength = szSourceLength ;
	cSourceString[szSourceLength] = '\0';
	return cSourceString;
const char* oclErrorString(cl_int error)
	static const char* errorString[] = {
		"CL_SUCCESS",
		"CL_DEVICE_NOT_FOUND",
		"CL_DEVICE_NOT_AVAILABLE",
		"CL_COMPILER_NOT_AVAILABLE",
		"CL_MEM_OBJECT_ALLOCATION_FAILURE",
		"CL_OUT_OF_RESOURCES",
		"CL_OUT_OF_HOST_MEMORY",
		"CL_PROFILING_INFO_NOT_AVAILABLE",
		"CL_MEM_COPY_OVERLAP",
		"CL_IMAGE_FORMAT_MISMATCH",
		"CL_IMAGE_FORMAT_NOT_SUPPORTED",
		"CL_BUILD_PROGRAM_FAILURE",
		"CL_MAP_FAILURE",
		"CL_INVALID_VALUE",
		"CL_INVALID_DEVICE_TYPE",
		"CL_INVALID_PLATFORM",
		"CL_INVALID_DEVICE",
		"CL_INVALID_CONTEXT",
		"CL_INVALID_QUEUE_PROPERTIES",
		"CL_INVALID_COMMAND_QUEUE",
		"CL_INVALID_HOST_PTR",
		"CL_INVALID_MEM_OBJECT",
		"CL_INVALID_IMAGE_FORMAT_DESCRIPTOR",
		"CL_INVALID_IMAGE_SIZE",
		"CL_INVALID_SAMPLER",
		"CL_INVALID_BINARY",
		"CL_INVALID_BUILD_OPTIONS",
		"CL_INVALID_PROGRAM",
		"CL_INVALID_PROGRAM_EXECUTABLE",
		"CL_INVALID_KERNEL_NAME",
		"CL_INVALID_KERNEL_DEFINITION",
		"CL_INVALID_KERNEL",
		"CL_INVALID_ARG_INDEX",
		"CL_INVALID_ARG_VALUE",
		"CL_INVALID_ARG_SIZE",
		"CL_INVALID_KERNEL_ARGS",
		"CL_INVALID_WORK_DIMENSION",
		"CL_INVALID_WORK_GROUP_SIZE",
		"CL_INVALID_WORK_ITEM_SIZE",
		"CL_INVALID_GLOBAL_OFFSET",
		"CL_INVALID_EVENT_WAIT_LIST",
		"CL_INVALID_EVENT",
		"CL_INVALID_OPERATION",
		"CL_INVALID_GL_OBJECT",
		"CL_INVALID_BUFFER_SIZE",
		"CL_INVALID_MIP_LEVEL",
		"CL_INVALID_GLOBAL_WORK_SIZE",
	const int errorCount = sizeof(errorString) / sizeof(errorString[0]);
	const int index = -error;
	return (index >= 0 && index < errorCount) ? errorString[index] : "Unspecified Error";
#define HDASHLINE "-----------------------------------------------------------\n"
void oclLogBuildInfo(cl_program cpProgram, cl_device_id cdDevice)
	// write out the build log and ptx, then exit
	char cBuildLog[10240]={0};
	cl_int ciErrNum =clGetProgramBuildInfo(cpProgram, cdDevice, CL_PROGRAM_BUILD_LOG, sizeof(cBuildLog), cBuildLog, NULL );
	if(ciErrNum!=CL_SUCCESS)
		printf(" Error %s in oclLogBuildInfo Call !!!\n\n", oclErrorString(ciErrNum));
	else
		printf("\n%s\nBuild Log:\n%s\n%s\n", HDASHLINE, cBuildLog, HDASHLINE);
		FILE *stream = fopen( "BuildInfo.log", "w" );
		if (stream==NULL)
			return;
		fprintf( stream, "%s", cBuildLog);
		fclose( stream );
int main(int argc, char** argvs)
	cl_platform_id clSelectedPlatformID=NULL;
	char *pOclSource=NULL;
	char cBuffer[1024];
	cl_uint ciDeviceCount;
	cl_int ciErrNum;
	cl_device_id devices[8];
	cl_context contexts[8];
	cl_program programs[8];
	cl_command_queue commandQueues[8];
	size_t srcLen=0;
	pOclSource=oclLoadProgSource(argvs[1],&srcLen);
	ciErrNum = oclGetPlatformID (&clSelectedPlatformID);
	ciErrNum = clGetPlatformInfo (clSelectedPlatformID, CL_PLATFORM_NAME, sizeof(cBuffer), cBuffer, NULL);
	if (ciErrNum == CL_SUCCESS)
		printf(" CL_PLATFORM_NAME: \t%s\n", cBuffer);
	ciErrNum = clGetPlatformInfo (clSelectedPlatformID, CL_PLATFORM_VERSION, sizeof(cBuffer), cBuffer, NULL);
		printf(" CL_PLATFORM_VERSION: \t%s\n", cBuffer);
	ciErrNum = clGetDeviceIDs (clSelectedPlatformID, CL_DEVICE_TYPE_ACCELERATOR|CL_DEVICE_TYPE_GPU, 0, NULL, &ciDeviceCount);
	ciErrNum = clGetDeviceIDs (clSelectedPlatformID, CL_DEVICE_TYPE_ACCELERATOR|CL_DEVICE_TYPE_GPU, ciDeviceCount, devices, &ciDeviceCount);
	for(unsigned int i = 0; i < ciDeviceCount; ++i )
		contexts = clCreateContext(0, 1, &devices, NULL, NULL, &ciErrNum);
			printf("Error %s in clCreateContext call !!!\n\n", oclErrorString(ciErrNum));
			break;
		commandQueues=clCreateCommandQueue(contexts,devices,0,&ciErrNum);
			printf("Error %s in clCreateCommandQueue call !!!\n\n", oclErrorString(ciErrNum));
			break;
		if((argc>2)&&(memcmp(argvs[2],"-debug",strlen("-debug"))==0))
			programs=clCreateProgramWithSource(contexts,1,(const char**)&pOclSource,&srcLen,&ciErrNum);
				printf("Error %s in clCreateProgramWithSource call !!!\n\n", oclErrorString(ciErrNum));
				break;
			ciErrNum=clBuildProgram(programs,1,&(devices),NULL,NULL,NULL);
				printf("Error %s in clBuildProgram call !!!\n\n", oclErrorString(ciErrNum));
				oclLogBuildInfo(programs,devices);
				break;
			size_t binary_size=0;
			ciErrNum=clGetProgramInfo(programs,CL_PROGRAM_BINARY_SIZES,sizeof(size_t),&binary_size,NULL);
			binary_size++;
			char *binary=new char[binary_size];
			memset(binary,0,binary_size);
			ciErrNum=clGetProgramInfo(programs,CL_PROGRAM_BINARIES,sizeof(size_t),&binary,NULL);
			char filename[256]="test.ir";
			FILE *fp=fopen(filename,"wb");
			fwrite(binary,1,binary_size,fp);
			fclose(fp);
			delete binary;
		else
			programs=clCreateProgramWithBinary(contexts,1,&devices,&srcLen,(const unsigned char**)&pOclSource,&ciErrNum,NULL);
				printf("Error %s in clCreateProgramWithBinary call !!!\n\n", oclErrorString(ciErrNum));
				break;
				break;
		//#endif
		printf(" ---------------------------------\n");
		//clGetDeviceInfo(devices, CL_DEVICE_NAME, sizeof(oclDevInfo.deviceName), &oclDevInfo.deviceName, NULL);
		//printf(" Device: %s\n", deviceName);
		//oclPrintDevInfo(devices);
	return 0;
Weibin_T_
summary missing....
post again:
My project work well if i compile it from opencl source file(test.cl) with clCreateProgramWithSource function. and save the cl program binary into an ir file(test.ir).
When i recompile the cl program with clCreateProgramWithBinary , it gets an error while clBuildProgram is called.
The same code works well on NVIDIA and AMD GPU platforms, except the intel mic card(5110p).
Is there something wrong with my code or intel opencl sdk?
This problem has trapped me for servel days, can anyone help me?
