hi
i just bought a the CPU i7-13700KF that on amazon i saw was 5.4 GHz but on my pc is 3.6 GHz.
can please someone tell me if the only way is to overclock or i have to activate something ?
thanks
5.40GHz is the max turbo frequency:
You will not be running at this speed all the time.
i saw that i have to activate intel boost...is this what i have to do to have my 5.4 GHz ?
Your motherboard may have a setting to enable or disable turbo boost.
If turbo boost is enabled, your processor will automatically increase speed as needed.
Please read:
What is Intel Turbo Boost Technology and How Does it Work?
Why Am I Not Getting the Intel Turbo Boost Frequency?
My Intel Core Processor Does Not Reach the Maximum Turbo Boost Frequency
Frequently Asked Questions for Intel Turbo Boost Technology
ok thanks so much to all of u...now i will try
have a nice day wherever u are hahah
i have now 2 questions...
1. the boost is enabled on auto...so now the cpu could go from 3.6 (standard) to 5.4 GHz ?
2. i discovered that i can change the phisical and logic ratio in the bios...i have a i7-13700kf so max overclock is 5.4 GHz...if one day i decide to change frequency i should set a 54 multiplier to get 5400 MHz. but what happens if for example i set 100000 Mhz ?
Hello @alexis_
We understand you still have questions regarding the Intel® Turbo Boost Technology and the Intel® XTU, we will be more than happy to provide you with the answers.
Please keep in mind that maximum frequency is automatic and dependent on working conditions. So, it will depend on the tasks or processes you run, if the workload demand is high and there are no physical constraints, then the processor may operate at or close to the Turbo frequency.
Regarding the Intel XTU, it’s best to increase these multipliers progressively by small steps, reboot, and then check for stability, rather than changing any settings dramatically.
The same applies with the “Processor Cache Ratio”. This adjusts the frequency of the part of the CPU that connects the cores to the processor cache. Setting the Cache Ratio at a lower frequency than the Core Ratio can result in lower performance.
You can have more information here: https://www.intel.com/content/www/us/en/gaming/resources/overclocking-xtu-guide.html
Jose B.
Have a nice day
Hello alexis_
Thank you for letting us know.
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jose B.
