Hello, I'm a computer science student and I'm doing some research on the Intel Core i7-6900K processor. The thing is that I must find very specific information on this processor and its architecture. I've looked through the official Datasheets (volume 1 and 2 and the spec update) and the Intel® 64 and IA-32 Architectures Software Developer's Manual (Volume 1, basic architecture) and so far the information found is scarce in comparison of what I still need to find. On a list, that information would be:
- The instructions per cycle this processor is able to processes, and specifically the number of instructions per fetch, decode, issue and commit of the pipeline.
- The size of the buffers, specifically the size of the instruction window and the Load-store queue size.
- The bandwith and the latency to the main memory
- The arithmetic logical units (ALUs) for the integer operations, and the ALUs for the floating point operations
For the ALUs I found something on the Sofware Developer's Manual: "Three full arithmetic logical units", 2.2.3.2 Execution Core at page 43 where I also found "Four-wide decode unit can decode 4 instructions per cycle or 5 instructions per cycle with Macrofusion", but is this information valid for the processor that I'm looking for? On the Table 2-2. Key Features of Most Recent Intel 64 Processors, the latest processor is from 2011, and I'm looking for information of a 2016 processor. Are there any other recommended documents that I might read to find some of the other information I'm looking for?
Thank you very much for any advice or help.
Hello christianzanger ,
At the following link you can find the processor specifications:
http://ark.intel.com/products/94196/Intel-Core-i7-6900K-Processor-20M-Cache-up-to-3_70-GHz?q=%20i7-6900K http://ark.intel.com/products/94196/Intel-Core-i7-6900K-Processor-20M-Cache-up-to-3_70-GHz?q=%20i7-6900K
And at the following links you can check for more detailed information about the processor information:
http://www.intel.com/content/www/us/en/support/processors/desktop-processors/intel-high-end-desktop-processors.html http://www.intel.com/content/www/us/en/support/processors/desktop-processors/intel-high-end-desktop-processors.html
http://www.intel.com/content/www/us/en/support/processors/000006513.html http://www.intel.com/content/www/us/en/support/processors/000006513.html
http://www.intel.com/content/www/us/en/support/processors/000007093.html http://www.intel.com/content/www/us/en/support/processors/000007093.html
I hope this can help you.
Ivan
Ivan
These links helped me on some of the points I already had, so they assured that the data is correct. Thank you!
Here are some other links that can help you :
https://en.wikipedia.org/wiki/Central_processing_unit https://en.wikipedia.org/wiki/Central_processing_unit
https://en.wikipedia.org/wiki/Floating-point_unit https://en.wikipedia.org/wiki/Floating-point_unit
Also, there is a post here where you can get more information:
https://software.intel.com/en-us/forums/intel-isa-extensions/topic/283562 https://software.intel.com/en-us/forums/intel-isa-extensions/topic/283562
Ivan
Thank you, I was able to find some of the information on those links and the other missing info after some research on other sites.
You're very welcome!
Please let me know if you need anything else.
Ivan.
