Processors
15406 Discussions
Core i7-6900K Intel 64 architecture specifics
Hello, I'm a computer science student and I'm doing some research on the Intel Core i7-6900K processor. The thing is that I must find very specific information on this processor and its architecture. I've looked through the official Datasheets (volume 1 and 2 and the spec update) and the Intel® 64 and IA-32 Architectures Software Developer's Manual (Volume 1, basic architecture) and so far the information found is scarce in comparison of what I still need to find. On a list, that information would be:
  • The instructions per cycle this processor is able to processes, and specifically the number of instructions per fetch, decode, issue and commit of the pipeline.
  • The size of the buffers, specifically the size of the instruction window and the Load-store queue size.
  • The bandwith and the latency to the main memory
  • The arithmetic logical units (ALUs) for the integer operations, and the ALUs for the floating point operations
For the ALUs I found something on the Sofware Developer's Manual: "Three full arithmetic logical units", 2.2.3.2 Execution Core at page 43 where I also found "Four-wide decode unit can decode 4 instructions per cycle or 5 instructions per cycle with Macrofusion", but is this information valid for the processor that I'm looking for? On the Table 2-2. Key Features of Most Recent Intel 64 Processors, the latest processor is from 2011, and I'm looking for information of a 2016 processor. Are there any other recommended documents that I might read to find some of the other information I'm looking for?
Thank you very much for any advice or help.
These links helped me on some of the points I already had, so they assured that the data is correct. Thank you!
Thank you, I was able to find some of the information on those links and the other missing info after some research on other sites.
You're very welcome!
Please let me know if you need anything else.
Ivan.
