Is the older Intel Thermal Solution BXTS15A cooler adequate for the new 10th gen i9-10900 CPU. I believe it is from 3rd party advertisers but I do not trust info on new high end CPU.
Hello Douglas,
Were you able to check the previous post and check our recommendations? Please let me know if you need more assistance.
Sebastian M
Hello Douglas,
The Intel® Thermal Solution BXTS15A is compatible only for LGA-1151 K skus processors, you can check that here, under Description. The Intel® Core™ i9-10900 Processor is an FCLGA1200 non k processor, check the specifications here. Based on this, they are not compatible.
Your Intel® processor already comes with a preinstalled cooler Part Number K69237-001 (HAD-X). In case you are planning to get a more powerful cooler for gaming, rendering, overclocking, etc. You might want to contact the different cooling solutions manufacturers for compatibility between their products with this specific processor.
Sebastian M
Hello Douglas,
Thank you for the update.
We do not validate third-party websites, based on our documentation and specifications that cooler is not compatible with this CPU, so we cannot ensure if it will work or not.
Even though you are not planning to overclock, gaming and video editing are considered CPU-intensive tasks, and for this it is recommended to use a better cooler than the one included by default, specially a liquid cooler might be the best choice, please check here for more information.
This really depends on the performance that you want to get, so it is completely up to you whether you want to get a different cooler or not. Remember to contact the different cooling solutions manufacturers for compatibility between their products with this specific CPU, recommendations and installation advice.
Sebastian M
Hello Douglas,
Sebastian M
Hello Douglas,
We received a notification that one of our previous posts was marked as a solution, so we think and hope that our previous recommendations were useful to you.
Based on that, we will proceed to close this inquiry, if you have any additional questions, please post a new thread since this one will no longer be monitored.
Sebastian M
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
