I just built my first pc and I can't get it to boot. I test booted it on a flat bench and I got into the bios, but after I assembled the components in the case I have not been able to boot. The CPU debug LED on my msi mpg gaming plus board is on, which led me to re-install the cpu and the cpu power cables, but im still having the same issue. Is my cpu dead?
If you got to the bios once, the cpu is/was working. What you have done since is the problem. We cannot debug MSI motherboard problems. You did not provide a motherboard model number, or a cpu model number.
Your best place to start is with MSI support for their board.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
