I'm trying to determine if there's an issue with my CPU, whether the laptop manufacturer throttled the base speed, or if there's something else going on.
I have a Dell Vostro 5502 running Windows 10 Pro 10.0.19042. I've been having a few other problems with this laptop since I bought it two months ago which has led to a hard drive replacement and a clean installation of Windows via the Windows Media Creation Tool.
As I was surveying the system after the OS reinstall, I noticed that task manager lists my CPU's base speed as 1.69 GHz, but I believe my processor's correct base speed is 2.80 GHz. See attached image.
The only thing I found in Microsoft's documentation regarding this discrepancy involves computers with Hyper-v mode enabled which I don't believe to be the case here.
I downloaded and ran the IPDT and the CPU frequency test fails every time. Attached are the full test results and the frequency check results. The test is expecting 2.80 but is measuring 1.68855. I also ran Dell's SupportAssist CPU Test, but it only provides "PASSED" as the results.
All drivers and BIOS are up to date. Interestingly, System Information lists the processor as follows: "11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80 GHZ, 1690 MHz, 4 Core(s), 8 Logical Processor(s)" and in the registry, ~MHz's DWORD value is 0x0000069a (1690). I suspect Dell set the clock speed at 1.69GHz for some reason, but it would be disappointing if that's what it needs to be at to avoid damaging the processor.
Thank you all for your input.
Replying to add that my only available power management mode is the Balanced Plan which lacks the advanced power settings that previously allowed for manually setting the processor power minimum and maximum, but using Microsoft's new slider in battery management I set it all the way to best performance for both AC/battery power.
Hello luisin2,
Thank you for posting on the Intel* Community.
To better assist you, can you please provide the below details?:
Maria R.
Hello luisin2,
Thank you for your response.
For highly-customized systems as laptops, Intel just provides the CPU in stock settings, and we do not have control over any customization that the equipment manufacturer has performed, so we cannot confirm if the Original Manufacturer will consider this as normal behavior or expected result.
However, since your system fails the IPDT test, chances are that the processor may be failing and even though we cannot provide a diagnostic we want to provide you with some recommendations:
In this case, as we mentioned, we can only provide recommendations, please contact the manufacturer for further assistance in case the system starts crashing or failing so they can assist you with troubleshooting steps for your specific systems or may provide warranty options.
I will proceed to close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Maria R.
