If i have a Z490 motherboard and a i9 10900 (non-K) processor can i use 3600/4000/4400 Mhz DDR4 memory in it?
Hello Donnovan,
This Intel® Core™ i9-10900 Processor supports DDR4 memory at 2933 MHz, this is the maximum speed supported by the CPU in terms of memory, check that here under Memory Specifications:
Remember that this is a locked CPU, therefore; it is not supported for ocerclocking. However, in some cases depending on the motherboard and RAM, you may be able to increase the speed of the RAM either manually, or using Intel® Extreme Memory Profile (Intel® XMP):
https://www.intel.com/content/www/us/en/gaming/extreme-memory-profile-xmp.html
You need to keep in mind that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications.
Based on this, you can check with your system manufacturer (OEM) and the RAM's manufacturer for the speeds supported, nevertheless; if you operate the memory beyond 2933 MHz, it can become unstable and reduce the useful life of the CPU and other components.
Sebastian M
Hello Donnovan,
Sebastian M
Thanks for your answer Sebastian,
If i use a 2933 Mhz memory in it, can i use 1.2 or 1.35 Volts memory or i need to use 1.2 Volts memory?
I looked for some 2933 Mhz memory and i mostly find 1.35 Volts ones.
Hello Donnovan,
Thank you for your reply.
I am attaching the Datasheet for this i9-10900 processor, please check the page 17, section 2.1 "System Memory Interface": DDR4 I/O Voltage of 1.2.
In that case, you can still check with your motherboard and RAM's manufacturer for memory compatibility, since some RAMs will have SPD voltage (which is lower e.g. 1.2V) and tested voltage (higher one, e.g. 1.35V, most likely with Intel® XMP)
Sebastian M
Hello Donnovan,
Were you able to check the previous post with the information provided? Please let me know if you need more assistance.
Sebastian M
Hello Donnovan,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
