Good afternoon, I work as a freelancer and develop websites, recently I began to notice a strong heating of the computer, it does not turn off, but the laptop itself is hot and it worries me, I started looking for the reason. At first I thought that it was IDE, because while working with it, the active fan began to work and after 30 minutes the keyboard was very hot (in the area of the keys), but this was not always the case, and I figured out that this was due to one template that I was ordered, and when I work with it in the IDE of processes it is 100% loaded and it reaches about 90-95C, here is an example of the code:http://lviv2022.in.ua/, but I developed the code myself and do not understand what can strain the processor so much in it, I did not find recursions there, maybe someone faced a similar problem?
I read this https://community.intel.com/t5/Processors/i7-7700k-High-Temperature-when-load-is-100/td-p/299957, but on this more modern processor, the temperature is lower under load, and I do not understand what to do
Well, that website looks like spam to me.
Have you cleaned the heat sink?
have you re-applied the thermal paste?
Have you made sure there is no dust blocking the air vents?
The site is really not the most white topic, but as a rule, such people pay money)
Of course, I carried out all the standard procedures, and I keep the fan clean, never put my laptop on a blanket or other dusty places. Notebook: Acer v3-571g, I disassembled it many times and changed the thermal paste myself, from this side of the problem I exclude, I test the operation of the fan with a lighter and it works fine, there are no problems with cooling. I think so at least
Hello brivant,
So we can have more information from your system, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
- Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Run the Intel® Processor Diagnostic Tool and send the results either in a screenshot or .txt file. To save the report, once the test is done, click on "File >> View Results File" and attach the .txt file to your reply.
3. While working in the code you mentioned above, please provide a screenshot of the Task Manager: Press Ctrl+Shift+Esc to open the Task Manager with a keyboard shortcut or right-click the Windows taskbar and select “Task Manager.”
4. Is this behavior only happening while developing that specific code? Or will also happen in other tasks?
Sebastian M
Hello brivant,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Hello brivant,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
