On a intel DP55KG extream mobo with an intel core i7 cpu 860. When I turn on the computer I get overheat warning beeps, when I press the reset button the computer starts with message ( The processor was shutdown due to overheating) while running temp is @ 30 degrees celsius. Is the some kind of delay for the pump to start?
- Tags:
- Data Center Cooling
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
Hi zen221,
The BXTS13X Liquid Cooling Thermal Solution is fully compatible with the processor. Please verify if it is properly attached to your motherboard according to the information below.
http://www.intel.com/support/processors/sb/CS-034340.htm Desktop — BXTS13X Liquid Cooling Thermal Solution Installation Instructions
The processor and motherboard support memories of DDR3 1066/1333/1600MHz.
The pump of the liquid cooling starts working since the beginning, touching the top of the pump, you can feel the water moving.
Mike C
It is working the problem is when I first turn on the computer I get the overheating beeps, if I press the reset button the computer it starts. If I do a soft reset it starts normally. If I power off and turn it back on the issue is there again. I've had this motherboard and processor for a few years now. I was using a corsair H100i until it stopped responding to it's software. Corsair suggested a replacement but I decided to use the TS13X. I tested the processor with "Intel Processor Diagnostic Tool 64bit\Win-IPDT64.exe" it passed everything. I was on chat with Intel support and the conclusion that we came to other than testing the processor and updating the BIOS was to reseat the memory and then try to reseat the processor.
--- Testing Processor 1 ---
--- IPDT64 - rev 2.20.0.0.W.MP ---
--- Start Time: 12/07/2015 13:05:16---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 58 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7 860 2.80GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 2.80
Detected CPU Frequency is --> 3.29229
CPU Frequency Test Passed!!!
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 137
Base Clock test Pass ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 374.4
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.31663e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> No
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> No ---> No Test Required
PCLMULQDQ - Polys Carry-Less Multiply Supported --> No ---> No Test Required
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
No AVX AES PCLMULQDQ Tests required
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel(R) P55 Chipset
Chipset Stepping : B2
No device connected to PCI-to-PCI Bridge Controller
1 device connected to PCI Express Port 1
1 : SB Recon3D PCIe Audio Controller
1 device connected to PCI Express Port 8
1 : Standard Dual Channel PCI IDE Controller
1 device connected to SATA Controller 1
1 : WDC WD5000AAKS-00A7B2 ATA Device
2 device connected to SATA Controller 2
1 : WDC WD10EZEX-60M2NA0 ATA Device
2 : TSSTcorp DVD+-RW TS-H653A ATA Device
6USB devices detected
1 : USB Composite Device
2 : NVIDIA Stereoscopic 3D USB controller
3 : USB Composite Device
4 : Xbox 360 Controller for Windows
5 : USB Input Device
6 : 802.11n USB Wireless LAN Card
--- Platform Controller Hub Test Completed!!! ---
..Query 3..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Intel(R) Integrated Graphics Device not supported on this processor..
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 47 degrees C below maximum.
--- Test End Time: 12/07/2015 13:09:16---
System Information
Processor Name: Intel(R) Core(TM) i7 CPU 860 @ 2...
Hi zen221,
It is necessary to narrow down the issue first. Your processor is over clocked now. According to Intel® Processor Diagnostic Tool.
Please change BIOS settings to default, Processor Base Frequency is 2.8GHz (4 Cores), Let see the behavior. Over clocking produces random issues.
Mike C
Check the power to TS13X, try different connector.
