Hi there ,need your advice .For last few weeks graphical artifacts in browser, mostly in youtube, Impossible to install any build of windows 10 "windows setup cant configure hardware" or just blue screen. Artifacts in photoshop camera raw,lines, dots during adjustments.
Tested system with AIda64,(CPU FAIL,) memtest86/64,(pass) IPDT Imc fail.
Tested gpu in other pc -no artifacts
Replaced psu.
Tested cpu with another moterboard,same issue.
During the tests cpu not overclocked
Any ideas? Thank you
5820k
asus x99 m ws/se
evga gtx 1070
predator hyperx 4x4gb 2133
Bios updated
New hdd
Hello Lakeside,
Thank you for posting on the Intel ® communities.
I can see that you are experiencing issues with your processor.
In order to assist you in the best way I would like to request an System Support Utility report. This report can be generated from our tool, you can refer to the link below so you can download it:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Make sure to attach the created report to this thread.
I would also like to mention that I have edited your response and I have added all of the information provided in a .txt file which has been attached, this is to have a faster and easier access at the different posts.
David V
Thank you for your time,i just contacted online support also. SSU report attached. Hopefully you will be able to help me.
Hello Lakeside,
Thank you for your response.
Please download the Intel ® Extreme Tuning Utility from the link below:
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-
Once downloaded, please run it and perform a stress test on the processor, once completed, please take a screenshot of it and attach it to this thread.
David V
Hello Lakeside,
I have sen you a private message with further steps to follow in order to address the problem you are experiencing.
Please check your private message inbox.
David V
Hello CHESTERBESTERFESTERTESTER,
Thank you for your response and for posting in our Intel ® communities
In this case, your Issue will be addressed in here Re: /thread/145974 Imc Fail 5820k
We will proceed to close this ticket so we can unify your inquiry.
I hope this helps.
Diego S.
Intel (R) Customer Support Technician
Under Contract to Intel (R) Corporation
For those who are still looking for a solution to this issue:
![](/skins/images/71A9511A625CE5D5D45FB59952A4AA71/responsive_peak/images/icon_anonymous_message.png)
