My customer have the design back from manufacturing. The design is very similar to the DDR5 CRB but they are counting on the VCC_VNNEXT_1P05 and VCC_V1P05EXT_1P05 to be supplied from the CPU FIVR.
For now they don't see that the processor is executing any BIOS code at all; although they see SPI flash transactions showing that the PCH at least is alive.
The question that they have for now is how configure the CPU Straps to use the CPU FIVR to supply VCC_VNNEXT_1P05 and VCC_V1P05EXT_1P05?
Please refer to the snippet from the schematics that processor CC34/CD34 are shorted and CA28/CC28 are shorted without being externally supplied.
they also got the Intel modular flash tool and they see how to configure VCCANA from FIVR; but we do not see how to do that for VCC_VNNEXT and VCC_V1P05EXT as below -
Hello EfiGO,
For us to further check this, please help provide the following details:
- Why are you reporting this issue?
- Are you having am issue with this processor?
- Are you designing a board/system with this processor?
- If yes, can you share more details about the design?
Michael L.
Hi Mike,
Thanks for the response.
1. Customer has a question which is more in detailed in the above description:
"The question that we have for now is how configure the CPU Straps to use the CPU FIVR to supply VCC_VNNEXT_1P05 and VCC_V1P05EXT_1P05?"
2. Customer have finished the 1st design (SBC) and recieved it, they are not seeing CPU is conducting any BIOS code for now/ and they have the above question as well. they need some guidance from Intel team
3. Yes. SBC and a complete system
4. They have a project of 50K pcs from the N100 solution with some of their partners. on prem mini computer.
I need Intel help to move forward.
Hello EfiGO,
Thank you for the quick reply.
Upon checking, we recommend that you should reach out to our Developer Zone Support or get in touch with a Field Application Engineer for specialized assistance. They are the best team who can assist you regarding this inquiry.
Also check this link on how to create an account:
Since you will be contacting our Developer Zone, I need to close this inquiry.
Michael L.
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
