instead of "Speed Optimizer" menu in newest XTU version (7.5.3.3) there is "Basic Tuning".
My client would like to use option "Optimize now" for one click OC but there simply isn't one.
He's using i7 12700KF with 360 AIO, so there is still some headroom for OC but he cannot do overclocking on his own.
We have done OC on this processor, but client updated his BIOS, so he reverted all the changes. We just wanted him to make "one click OC" without making an RMA.
I attach photos of how it should look and how it actually looks.
Thanks in advance
Hello MateuszMorele,
Thank you for posting on the Intel
- Was the options present before? If so, when did they stopped showing up?
Also, please download and install the Intel
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel
Click on "Next", save the report and attach it to your response.
Josue O.
logs from our customer are in the attachment.
Option was unavailable from the beginning.
Mateusz
Josue O.
In this case, I would like you to inform that a new version of XTU has been released, it is version 7.6.0.37. Please test it and let me know if the options you want are shown.
Also, it is important for you to know that the Speed Optimizer requires the following:
• Overclocking options must be enabled in BIOS
• The OC lockbit option must be disabled in BIOS
In case you don't know where to locate these options, please contact the motherboard manufacturer for assistance with their BIOS.
Josue O.
Josue O.
Problem isn't solved yet. We downloaded the newest version of XTU, but there seems to be some kind of problem with BIOS of this motherboard (Asus Prime Z690M-Plus D4). In the manual there is no single thing about overclocking, so our customer has to find it by himself.
Mateusz S.
after updating XTU our customer have seen this notification. I wonder if this is any relevant.
Mateusz S.
Thank you for the information provided, in this case, we would like to confirm if the settings for OC were found in the BIOS, if so, we would like to know if the speed optimizer option is showing up.
Also, please let me know if you have any other overclocking tools installed in the system.
Regarding the error message, what happens if you press on to continue?
Josue O.
We would like to know if you were able to check our previous post.
Remember to confirm if the settings for overclocking were found on the BIOS.
Also, remember to tell us if other OC tools are installed in the system as well as what happens if you press continue on the error message.
Josue O.
by performing a clean install of XTU the problem went away. Our customer can use OC through XTU without any problem.
Also the notification went away too.
Mateusz S.
I am glad to hear that the issue is now solved and everything is working fine.
Josue O.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
