When i fist recieved the i7-10700k i remember it boosting by itself to 5.1 ghz now it only goes up to 4.7ghz is there a way to get it to go back to 5.1ghz?
First of all, the achievable Core frequency gets lower as the number of busy Cores goes higher. The highest Core frequency is going to be seen when only a single Core is busy. Typically, if you are trying to monitor the boosting that is taking place, you are introducing a multi-core load and this is going to result in the achieveable boost rate being lower.
