Processors
PC gamer
Klebold59
bonsoir comment désactive un ships set graphique qui fait conflit dans un jeux au lieux de laisse la carte graphique gérer ? même en le désactivant j'ai toujours le même souci aidez moi SVP
AlHill
You are going to have to explain in greater detail what your problem is.
Also, So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
