Hello Kdbxbxk
Thank you for posting on the Intel️® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate. Please share with us the following information:
- What is the laptop model?
- Is this a new system?
- When did this issue start?
- Can you run the Intel® Processor Diagnostic Tool? Let us know the results.
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
David G.
David G.
