Processors
13139 Discussions
Temperature Range
Sahil_Honeywell
I have 2 questions:
1) For the processor Xeon E2278GE, What is the minimum & maximum temperature range for the processor cores?
2) Some processors (such as Xeon W-1290TE) specify the  max junction temperature (Tj) while some other processors (such as Xeon Silver 4309Y) specify max case temperature (Tc) only. My question is why do some processors specify Tj only others specify Tc only? Which one should I use when considering the maximum upper limit of the core temperature?
Victor_G_Intel
Hello Sahil_Honeywell,
In regard to these two processors the Xeon E2278GE, and the Xeon W-1290TE please bear in mind that the support for them is provided in our embedded community; therefore, please submit your question for them there. You can find the link to the community down below.
Support for Intel® embedded products
https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Note: A designated team will help you out once you post your question.
In regard to the temperature that you should use with any other processor but the ones that belong to embedded systems, you can use the following link as a reference for the temperatures you can take into consideration.
Thermal Management for Intel® Xeon® Processors
https://www.intel.com/content/www/us/en/support/articles/000006710/processors/intel-xeon-processors.html
Victor G.
Intel Technical Support Technician
JoseH_Intel
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. We will try to reach you as a very last time on next Friday 17th. After that the thread will automatically be archived.
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Paul_R_Intel
I hope you are doing great, We are following up on your thread that is still open, we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution. Since we have not seen an update for several days, the thread will automatically close after 2 business days. You can still re-open it by replying back.
Paul R.
Intel Customer Support Technician
