Processors
13146 Discussions
Thermal throttle i7 10750h
YatharthYadav7
So i have the Alienware m15 r3 and my laptop seems to throttle when idle(doing nothing at all except HWMonitor on, is it common/okay to reach 100 degree when idle?
David_G_Intel
Hello YatharthYadav7
Thank you for posting on the Intel️® communities.
Run the Intel® Processor Diagnostic Tool to identify a possible problem with the processor:
If it passes the tests, the processor is not affected by changes in temperature. Also note that the maximum temperature allowed on the processor die (TJUNCTION) is 100 ° C.
If your system is up-to-date and temperatures are still high, we recommend that you check with your laptop's OEM for troubleshooting.
David G
Intel Customer Support Technician
David_G_Intel
David G
David_G_Intel
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
David G.
YatharthYadav7
Hi David,
I tried the solution and the problem wasnt with the cpu but with the cooling of the laptop ,i submitted my laptop to dell.Thanks for the help.
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
