Processors
15133 Discussions
Xeon E5 V3 dual socket supported model pairs
Hello All,
I would like to know the list of supported pairs for a processor from Xeon V3 family in a dual / quad configuration.
For example, can i put a 2680 V3 and 2670 V3 in the same motherboard.
I know that the higher clocked processor would automatically be under clocked to ensure both run at same speed.. but not sure.
I found some information on net, however its related to Xeon V2 family and it might not apply for V3 as there are significant architectural changes in V3.
Thank you.
Hello Gemi,
In regard to your concern, I would like to confirm the specific model of your processor?
Also, the model of the motherboard that you would like to use?
I am looking forward to heard from you.
Angie
Hi Angie,
PFB the requested info.
Processor : Xeon E5 2580 V3
Motherboard: Supermicro X10 DRL-i
Let me know, which all processors could be paired with this config. Thank you.
I have searched for supporting intel documentation and found the following at
http://www.intel.in/content/dam/www/public/us/en/documents/specification-updates/xeon-e5-v3-spec-update.pdf http://www.intel.in/content/dam/www/public/us/en/documents/specification-updates/xeon-e5-v3-spec-update.pdf
As per this URL, Page 7,
E5 2690 V3
E5 2680 V3
E5 2670 V3
E5 2660 V3
E5 2658L V3
E5 2648L V3
E5 2628L V3
E5 2690 V3
E5 2680 V3
E5 2670 V3
E5 2660 V3
E5 2658L V3
E5 2648L V3
E5 2628L V3
These all processors could be used in a single motherboard. Correct me if i am missing something.
E5 2690 V3
E5 2680 V3
E5 2670 V3
E5 2660 V3
E5 2658L V3
E5 2648L V3
E5 2628L V3
Hello Gemi,
Thank you very much for your reply.
Based on the information provided, at the Intel document the list that you have found it is related to the compatible families. Even though those are not the specific supported processors.
I can tell you this due to, there is not a specific confirmation that these processors are compatibles with the chipset (Intel® C612 chipset) for your Motherboard: Supermicro X10 DRL-i
So then, at this moment my recommendation, in order for you to get the proper compatible processors list, you will need to contact Supermicro and they will provide you with most accurate information that will help you to avoid any harm to your current board.
You can find the support contact for Supermicro at the following link:
https://www.supermicro.com/support/index.cfm https://www.supermicro.com/support/index.cfm
Hope I can hear from you soon.
Angie
