I have changed from an I5 4690k to an I7 4790k and having issue with the high temps when I am rendering or using stress test applications as the temps seems to be too high than normal at 70'c to 80'c
Before getting the i7 4790k, My i5 4690k was fine with temps but i cleared the CMOS before installing the i7 4790k
I would like to make this clear that I have reapplied thermal paste, reseated the Corsair h100i, cleared the cmos and updated to the latest BIOS but didn't solve anything.
I did have a look at this forum but I am not sure how to adjust the setting to match the correct BIOS setting of my MSI Gaming 3 Z97 Motherboard of the Intel specification.
Can someone please guide me how to apply the settings?
Specs
Intel Core i7 4790K 4GHZ
Nvidia GeForce GTX 970 4GB
Corsair Vengeance 1866MHZ 16GB RAM
Samsung Evo 500GB SSD
MSI Gaming 3 Z97
Corsair RM650x
Corsair H100i
Hello slim95:
In regard to your inquiry, according to the specifications of the processor, inside the case could reach up to 74.04°C and that is normal, so based on that it seems the processor is working fine.
Now, if the processor is reaching 90 or 95 those are risky temperatures and in that case there might be a problem with the PC.
If the PC is getting freeze, throttling or if it goes off by itself, those are symptoms of overheating, if the PC is not doing that, then it should be working fine.
We do have a tool to test the processor, it does an overall test including the temperature test, here is the link to install it, is the Intel® Processor Diagnostics Tool, and if the processor passed the test it means it is working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
About the question of how to get the proper BIOS settings, in order to get that information you just need to get in contact with MSI directly, since they are the manufacturer of the board they have all the details about the BIOS on it:
MSI's phone number: 1 626-271-1004
MSI's support site: https://us.msi.com/support https://us.msi.com/support
Any further questions, please let me know.
Alberto
Hello slim95:
I just wanted to check if the information posted previously was useful for you, and if you need further assistance on this matter?
Alberto
Hello
Sorry for the inactivity of this post I have ran the diagnostics tools and it passed all tests so cpu is fine and I am still waiting for MSI to get back to me regarding about the BIOS setting
Thanks for the troubleshooting and diagnostics
Slim
Hello slim95:
You are welcome, no problem at all.
Perfect, they should be able to further assist you in regard to the BIOS settings.
Alberto
Hello slim95:
I just wanted to check if MSI was able to provide the information you were looking for about the BIOS and if you need further assistance on this matter?
Alberto
Hi there
I have received information from MSI and I have applied the settings needed for the CPU and motherboard. I believe that the CPU is fine without MSI settings but made no difference so I am going to leave it as it is.
As am used to my i5 4690k load temp under 70'c I believe i7s is a hot processor
Hello slim95:
Thank you very much for letting us know those details.
We are sorry to hear that the MSI BIOS settings did not fixed the situation, we understand and respect your decision, even though it is reaching 70°C that is still expected, so as you mentioned we can say it is a hot processor.
Just in case, remember that the warranty on the processor with Intel is for 3 years.
Any other inquiry, do not hesitate in contact us again.
Alberto
![](/skins/images/0B743BCD37FD8EED134343C203D4D429/responsive_peak/images/icon_anonymous_message.png)
